Is there any option to convert Dynamic Physical load to Electric energy ???
Keerthivasan Ravisankar
@keerthivasan-hrKQir โ€ข Jun 10, 2026
Is there any process or idea of converting moving physical load to produce electric energy depending upon the load acting on the device that converts?๐Ÿ˜
For example;
Lot of vehicles move on road now and then, if the device that converts the dynamic load to electric energy merged on road makes sufficient energy that can glow a bulb near a road side village๐Ÿ‘ !!!
Is there any possibility to do like that??
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Jul 7, 2013
    Crystal roads are an area of research now do check this link for more details
    But this is highly pricy as of now
  • Keerthivasan Ravisankar
    @keerthivasan-hrKQir • Jul 25, 2013
    ConquerorCrystal roads are an area of research now do check this link for more details
    How to construct these type of materials...Like what are the things needed to get continuous electricity.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Jul 26, 2013
    rkvasan68How to construct these type of materials...Like what are the things needed to get continuous electricity.
    This method is not continuous electric supplier
    The crystals generate electric current by inverse piezo electric effect nothing special
    The amount of voltage generated is very low and as I heard recently it is not suitable or economically harvested till now
    Construction is nothing Just stress plates applying pressure on the cut crystals to begin charge development
  • meadowfield
    @relaxed-quick-broom • Jun 8, 2026
    Yes, converting dynamic physical load into electrical energy is technically possible, but the practicality depends heavily on scale and efficiency.
    The main working principles used today are piezoelectric systems and electromagnetic induction. For example, piezoelectric materials can generate small electrical charges when they are compressed, this is already used in things like pressure-sensitive mats, road studs, and experimental โ€œenergy harvestingโ€ speed bumps. Another approach is regenerative systems (similar to regenerative braking in electric vehicles), where motion energy is partially recovered instead of being wasted as heat.
    However, the limitation is always the same: energy output is relatively low compared to installation and maintenance costs. When traffic moves over a road, the system must withstand constant mechanical stress, and the energy harvested per vehicle is usually too small to justify large-scale power generation for something like lighting a village.
    That said, these systems can be useful for low-power applications such as roadside sensors, smart traffic systems, or IoT devices. In real-world implementation, infrastructure design and installation quality matter a lot, and contractors such as Handyman Singapore are often involved in practical deployment and maintenance work for small-scale or pilot setups in built environments.
    Overall, the concept works in theory, but right now it is more suited for niche applications rather than replacing conventional power generation.
