Is Power Transferred To Consumers Or Energy??0
Member • May 31, 2013
Energy is ability to do any work
Power is the rate at which the energy is used by an appliance
By this it is clear that Energy is delivered to the house and Depending on the power requirement of the house it is spentAre you sure? This action cannot be undone. -
But at the generating side, power is produced. So how could energy be transferred?. Power consumed by load with time is energy. So, finally, power is transferred. Isn't it?Are you sure? This action cannot be undone. -
Member • Jun 1, 2013
If you are talking in technical terms, at the generating side, energy is produced (strictly transformed) as defined by conqueror. Are you confused because generating stations are called power stations?naman2511But at the generating side, power is produced. So how could energy be transferred?. Power consumed by load with time is energy. So, finally, power is transferred. Isn't it?Are you sure? This action cannot be undone. -
Energy produced or power??? Output of alternator must be in kVA ..so this could be Energy?? M not confused with Power station....Anand TamariyaIf you are talking in technical terms, at the generating side, energy is produced (strictly transformed) as defined by conqueror. Are you confused because generating stations are called power stations?Are you sure? This action cannot be undone. -
Member • Jun 2, 2013
It is energy that is produced in generating stations. Power is the rate at which energy is produced. An X kVA alternator can generate X kVA-s energy every second.naman2511Energy produced or power??? Output of alternator must be in kVA ..so this could be Energy?? M not confused with Power station....
Take the case of a 1000W alternator. It generates energy at the rate of 1000 Watt-second or 1000 Joules per second when it is excited. For an hour, total energy generated is 1000 Watt-hour or 1000 x 3600 Joules. It is actually energy that is generated, power is a measure of how much energy can be generated per second.Are you sure? This action cannot be undone. -
Member • Jun 3, 2013
First Power Came Into picture, then Energy...Power should be what is transferred to consumers..and energy is consumption of power with time..isn't it??. So power is transferred...not energyAre you sure? This action cannot be undone. -
Concept of power is introduced to enable apple-to-apple comparison. e.g. running a fan vs. lighting a lamp for an hour, which should cost you more? If you remove time in this question, the answer would be indeterminate.Are you sure? This action cannot be undone. -
So bottom line is that energy is transferred nor power to consumers..??Are you sure? This action cannot be undone. -
Member • Jun 4, 2013
Energy is transferred to the customers
Power is consumption of energy by your deviceAre you sure? This action cannot be undone. -
Yeah. Energy is what is generated, transferred and consumed. Power is the rate at which it is done.Are you sure? This action cannot be undone. -
May be this would clarify things:naman2511So bottom line is that energy is transferred nor power to consumers..??
#-Link-Snipped-#Are you sure? This action cannot be undone. -
ok thanks..i got it 😀Are you sure? This action cannot be undone.
