does kinetic energy have any upper limit its lower limit would be zero but what about upper limit??0
Member • Feb 8, 2013
Definitely it's upper limit is also finite practically. Atleast on earth, force of friction is always an answer to your question, which retards the motion.Are you sure? This action cannot be undone. -
okay i get that practically v have a upper limit but what about dis case..
If velocity of anythng is equal to velocity of light (hypothetically) which is the maximum velocity of anythng as far as i know.... Bt if that thng's mass be inc.. Den v dnt knw hw much would the k.e be...???
And if any such thing is made is it possible to stay in earth's surface or would it escape earths gravitational field?????Are you sure? This action cannot be undone. -
Member • Feb 9, 2013
Each celestial object has an escape velocity that is defined by the gravitational field of that object. The escape velocity for earth is a small 11.2 km/sec, way below the speed of light.
<a href="https://hypertextbook.com/facts/2005/LeoTam.shtml" target="_blank" rel="nofollow noopener noreferrer">Speed Needed to Escape the Earth (Escape Velocity) - The Physics Factbook</a>
You better read some basic physics text on the theory of relativity for your other doubts. Too long to explain here.Are you sure? This action cannot be undone. -
Member • Feb 11, 2013
i know about escape velocity dats y i said nt practically bt what bout theoroticallyAre you sure? This action cannot be undone. -
You can calculate the escape velocity for any gravitational system using Newton's Laws. Only black holes prevent any escape. It is unlikely thaat anything within a black hole has a defined mass and shape that can acquire a KE enough to escape.Are you sure? This action cannot be undone. -
Member • Feb 14, 2013
hmmm....... that's true thanks a lot my old doubt has been clearedAre you sure? This action cannot be undone.
