@anoop-kumar-GDGRCn • Jun 19, 2012
Didn't used javap command..
but default constructor always added to class file, either it written in source code or not. did you tried for it JD java decompiler to generate source file from class file.
If you have any doubt just call super(); as first line in subclass *constructor without having any constructor in super class. see what will happen!!!!๐ -
@neeraj-iAaNcG • Jun 19, 2012
No need at all. There is always a default constructor as follows even if you dont declare yours,
It has following structure.
public class_name
@sookie-T06sFW • Jun 19, 2012
#-Link-Snipped-# I am getting the default constructor getting displayed for my java class using javap. Can you please share your java class along with javap command results?
Vikash Verma OP
@vikash-verma-jF0MOy • Jun 19, 2012
getting following error while using super(); in subclass constructor...๐
C:\Users\VIK\Desktop>javac *.java
B.java:6: cannot find symbol
symbol : constructor A()
super();
1 error -
Vikash Verma OP
I am getting no constructor using javap tool in my, class here goes the output of my class... ๐
your code please...
Vikash Verma OP
#-Link-Snipped-# does it always happen that for each and every java program javap tool will display at least one constructor...๐
@anoop-kumar-GDGRCn • Jun 20, 2012
Vikash Verma#-Link-Snipped-# does it always happen that for each and every java program javap tool will display at least one constructor...๐
Sure it will show you all class members using command javap -private <ClassName>
If your code is like this one
class super1{ } public class HelloWorld extends super1{ HelloWorld (String s) { s="ABC" ; } public static void main(String[] args) { System.out.println("Hello, World"); } }Then compile the code and use javap you will get following output
C:\Documents and Settings\<User>\My Documents\Downloads>javap -private Hell oWorld Compiled from "HelloWorld.java" public class HelloWorld extends super1{ HelloWorld(java.lang.String); public static void main(java.lang.String[]); }For class super1.
C:\Documents and Settings\<user>\My Documents\Downloads>javap -private supe r1 Compiled from "HelloWorld.java" class super1 extends java.lang.Object{ super1(); } -
Vikash Verma OP
@vikash-verma-jF0MOy • Jun 21, 2012
This is what my code is displaying...๐
C:\Users\VIK\Desktop>javac B.java
C:\Users\VIK\Desktop>javap B
Compiled from "B.java"
class B extends java.lang.Object{
@sookie-T06sFW • Jun 21, 2012
Vikash VermaThis is what my code is displaying...๐
}And can you Please tell what is your code? B.java?
I was just trying something and came to know that may be your B.java has declared constructor as "private" If you have its visibility as "private" then following command "javap B" will not show the private constructor. In order to view it you will have t explicitly run the command as "javap -private B".
@anoop-kumar-GDGRCn • Jun 21, 2012
my JDK giving error while running javap B.
While "javap -private B". is working fine.
#-Link-Snipped-# , can you confirm this. -
ianoopmy JDK giving error while running javap B.
#-Link-Snipped-# , can you confirm this.show me the error and your B.java ?
sookieshow me the error and your B.java ?
๐ฒ, its working, what's wrong , I was doing
Here is final conclusion
With public constructor Source: public class abc{ abc(){} public static void main(String[] args) { System.out.println("Hello, World"); } } Output C:\Documents and Settings\<user>\My Documents\Downloads>javap abc Compiled from "abc.java" public class abc extends java.lang.Object{ public abc(); public static void main(java.lang.String[]); } With private constructor Source: public class abc{ private abc(){} public static void main(String[] args) { System.out.println("Hello, World"); } } Output C:\Documents and Settings\<user>\My Documents\Downloads>javap abc Compiled from "abc.java" public class abc extends java.lang.Object{ public static void main(java.lang.String[]); } With private constructor C:\Documents and Settings\<user>\My Documents\Downloads>javap -private abc Compiled from "abc.java" public class abc extends java.lang.Object{ private abc(); public static void main(java.lang.String[]); } -
Vikash Verma OP
@vikash-verma-jF0MOy • Jun 24, 2012
#-Link-Snipped-# you are right...๐
