Ir sensor array
pchaubal89
@pchaubal89-A3DbBz โ€ข Oct 25, 2024
Hi
I would like to know about an ir sensor array that can give an output signal corresponding to the position of an ir object above it.
For eg.
If i place my hand above it, it should give me a unique signal as to where my hand is positioned with respect to it. Also i would like to know if its range can be altered.
  • Rifaa
    @rifaa-NaWZZ4 • May 14, 2009
    Ah.. IC no CE's had replied to you...do u still want any info.
    post back and I'll see what I can do
  • swapnakumar
    @swapnakumar-lJkNkk • May 27, 2009
    hi!!!
    if u can be more clear of your application as exactly what you want may be i can help you
  • RajdeepCE
    @rajdeepce-7UdrG8 • May 27, 2009
    do you want a strip type where you will have a combo of about 9 sensors (array) this is what you meant right but then performance will be different is that ok for you
  • swapnakumar
    try out pacific silicon sensor but it is NIR nera infra red
  • Munguti
    @munguti-MnxkmE • Jun 6, 2009
    @ swapnakumar
    Whats a nera infra red
  • just2rock
    @just2rock-DkmPtO • Jun 6, 2009
    hi...good question...sorry for noone relying on your queries๐Ÿ˜”....i was off from CE for long...anyways
    IR sensors are basically photocells that tracks motion& gives output on the recieved breikage of input signal flow cut.Yes range can be altered & customized as you want ,and it depends on what sort of IR sensor you are using.
    eg: for boom barriers you see near toll plazas ,they have beam sensors IR long range meant to stop boom fall upon car untill it passes barrier.
  • swapnakumar
    @swapnakumar-lJkNkk • Jun 7, 2009
    sorry its near infrared try silonex make you will get the sensors
