  • IR Light and Motor.
    Hari Prasath
    Hari Prasath
    @hari-GB3Lia
    Updated: Oct 26, 2024
    Views: 1.1K
    Hey guys.
    I'm Having a IR tx n rx, The matter is that i need to open a curtain using the IR Rx. and the input unit is a DC supply...
    deal2die
    Hey guys.
    What you have as a IR Tx? Any Remote? and which sensor you have used for Reception?
    And what you want to ask exactly you want to implement this system then what you need any mechanism that drives Curtain Motor or any circuitry for this?
    -GodFather
  • Hari Prasath
    MemberJul 20, 2011
    godfather
    -GodFather
    Yes I'm using a remote and I just asked a IR receiver from the shop which is commonly used in TV's..And i also have a photo diode..
    Wen the tx (remote) sends a signal, the motor have to spin and the curtain is opened.
    Any kind of mechanism that would make this is ok with me..
    deal2die
    Well as you are searching for mechanism, you can start a thread in Mechanical Section. So are you clear with your Receiver Circuitry? or not yet?
  • Hari Prasath
    MemberJul 21, 2011
    godfather
    ya. just found a circuit from a friend. will try and say what happens...
  • RRITESH
    MemberJul 21, 2011
    Hey, Don't use photo diode have a TSOP 1738 it has 3 terminal,etc.............
    and if you are ready to make this projects connected your I.R. Led to 555 astable mode. the value of Resistance and capacitor to have 38KHZ or near by ( this 38Khz is very good for IR application)
    the ouput terminal 3 of 555 should be connected to transistor. the reciver part is also easy first make this Tx and ask problem
  • Hari Prasath
    MemberJul 21, 2011
    RRITESH
    Thank you for the info.
    RRITESH
    Even you can use RC5 Remote but then it would be Complex System so Whatever Pritesh suggested is OK.
  • RRITESH
    MemberJul 22, 2011
    Is RC5 a wireless module??
    RRITESH
    RC5 is the Protocol, For More Info :- #-Link-Snipped-#
  • RRITESH
    MemberJul 22, 2011
    It was all about IR transmission with coding, I believe i have seen it before also.
    God father, I want to know have you ever implement it??
    RRITESH
    Yes, I have implemented RC5 Remote in my one project. at receiver side you need one Microcontroller. 😀
  • RRITESH
    MemberJul 23, 2011
    Yes, I have implemented RC5 Remote in my one project. at receiver side you need one Micro controller.
    If you are using micro controller at Rx side, then i think it must be a TV,DVD,etc .... Remote control. Is this true??
    If you want to use any micro controller ( programing) for that then you can use Decoder IC like HT 12E/D there are many like this you can also add a RF module like 433MHZ....!!
    RRITESH
    Yes We have use the Remote which follows RC5 protocol or NEC or whatever. and Mostly TV,DVD remote follows them.
    yes we can replace IR with RF Signal too.
  • martinSteve
    MemberAug 1, 2011
    First tell me about the censor which are being used by you.Answer can not be given without knowing about your censor.
  • RRITESH
    MemberAug 1, 2011
    12
    First tell me about the Sensor which are being used by you.Answer can not be given without knowing about your Sensor.
    The sensor is TSOP 1738 ( I.R. receivers) it has 3 pin.....
