IP address of remote device in a LAN using Java
krishprateek
@krishprateek-vrpct6 โ€ข Oct 23, 2024
i have written a code that should give me the ip addresses of all the devices connected in a wireless network.But it is just showing the ip address of the default gateway router and my own system. so plz can someone help me with this.
importjava.io.IOException;
importjava.net.InetAddress;
publicclass NetworkPing {
publicstaticvoid main(String[] args)throws IOException {
InetAddress localhost = InetAddress.getLocalHost();
// this code assumes IPv4 is used
byte[] ip = localhost.getAddress();
for(int i =1; i <=254; i++)
ip[3]=(byte)i;
InetAddress address = InetAddress.getByAddress(ip);
if(address.isReachable(1000))
System.out.println(address +" machine is turned on and can be pinged");
elseif(!address.getHostAddress().equals(address.getHostName()))
System.out.println(address +" machine is known in a DNS lookup");
else
System.out.println(address +" the host address and host name are equal, meaning the host name could not be resolved");
    @thebigk • Jan 4, 2013
    I added code tags, and it seems to have messed up the entire formatting. Could please post your code again so that I can make it appear properly?
    Update: Fixed! ๐Ÿ˜€
  • durga ch
    @durga-TpX3gO • Jan 5, 2013
    I am a java illeterate but as I read from your code, loks like you are trying to reach all IPs 1.1.1.1 to 255.255.255.255 and see whch ones are reachable and then returning the ip ??
    if your logic is different let me know.
    can I know the networj setup where you are using this script???
  • KenJackson
    @kenjackson-mBf7HF • Jan 7, 2013
    I think isReachable() uses raw sockets, which requires root (or Administrator) priviledge.
    BTW, if you just want the answer and aren't specifically trying to write a program, the <a href="https://nmap.org/" target="_blank" rel="nofollow noopener noreferrer">Nmap: the Network Mapper - Free Security Scanner</a> program does a very good job.
