  • interfacing a temperature sensor
    vza
    Member
    Updated: Oct 23, 2024
    Views: 1.0K
    Hey guys
    Need some help here....,i have this circuit that senses the temperature of an environment then converts the change into 8 bit digital form,how to i incorperate the interface circuit????
  • sauravgoswami
    MemberJul 28, 2008
    why dont ya use an ADC,you can use RTD or PT 100 depending on your temp.range
  • reachrkata
    MemberJul 30, 2008
    From what I understand from vza, he already has a circuit that gives a 8-bit code corresponding to the temperature. So there is no need of the ADC.
    To incorporate the interface, you first need to know if the 8-bit data is in serial form or parallel form. If parallel, you just need to connect the 8 data outputs of the circuit to any Microprocessor port and use the data.
    If serial, then connect it to a SPI or UART port (as the case may be).
    -Karthik
