  • Install Turbo C On Windows 7 Home Premium
    Updated: Oct 26, 2024
    Views: 1.1K
    i am using windows 7 home premium os i m unable to install turbo c and any c++softewar without changing the os .if u know any better idea it will help me .the error is "the version of this file is not compatible with the version of windows you are running".
    check this out : #-Link-Snipped-#
    AdministratorAug 12, 2012
    #-Link-Snipped-# We are not sure what problem you're facing. Are you stuck at some step? Why do you need to change OS?
    most of 7 users have trouble with compatibility with TC. As Windows7 is 32-bit/64-bit while C is 16-bit or 8-bit program (I am not sure which one though 😛) it has some compatibility issues.
    Unless we know the exact problem, answering anything in this thread is going to be pretty useless 😁
  • Aseem Patel
    MemberAug 17, 2012
    In a direct way there is no compiler that support Windows 7. ya but still u can install TURBO C on W7 using virtual box
  • rahul69
    MemberAug 17, 2012
    There are many ways:
    1. Use VMWare/Virtualbox to create virtual machine and install xp in it and then turbo C.
    2. Use DOSBOX , (although it changes look and feel and shortcuts)
    3. Use Dev Cpp instead of Turbo Cpp.
  • er_aman08
    MemberAug 19, 2012
    just use dos box the setup below it works....
    i m also using the same in this u didnt need to mount image etc things just install nd enjoy...
  • Rabirabi
    MemberSep 1, 2012
    very easy solution:
    Download "Turbo C simulator" from download.com & install it...no need to install TC.
    u will get Turbo c in full screen mode as that in XP.
  • Umesh Kumar Rai
    MemberNov 6, 2012
    Even I tried to install TC in windows 7, but could not. And didn't get suitable solution
  • [Prototype]
    MemberNov 6, 2012
    Just don't install it in C drive because total C drive will require permissions for read and write. Install in some other drive and run the TC.EXE in the compatibility mode of Win XP.
    I don't use this shitty thing, GCC is already there, but if I remember correct, that's what worked for me when I tried to do it in my friends computer.
