Inside a calculator
nenuadwani
@nenuadwani-pb4lOD โ€ข Oct 27, 2024
HELLO,
I am an electronics and communication engineer persuing third year.I opened a calculator and was amused to find that it contains only a lcd, a chip and a ciruit layout that helps in the input through the keypad.Now my mind is boggling as to what is there in that chip that makes a calculator work.There may be some programming about which I am sure. But I want a detailed information as to how all this happens. Can some one help me please.
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Sep 14, 2010
    In general words , Calculator works on the calculations using logic gates.
    It involves CMOS (Complementary metal-oxide-semiconductor) Technology for the circuit.
  • nenuadwani
    @nenuadwani-pb4lOD • Sep 15, 2010
    Ya I am aware of that. I have found out that a small IC is attched to the chip which stores the programming. But the model i opened had the circuit made on a polythene like structure and the circuit was painted with black similar to a layout on a PCB. I still want to know the detailed working.
    @saandeep-sreerambatla-hWHU1M • Sep 16, 2010
    you can design a basic calculator using logical gates rite?
  • nenuadwani
    @nenuadwani-pb4lOD • Sep 17, 2010
    thats right. But what about the plastic material on which the circuit is drawn. How signals move through that?
  • aj_onduty
    @aj-onduty-BvuwMK • Sep 17, 2010
    nenuadwanithats right. But what about the plastic material on which the circuit is drawn. How signals move through that?
    Are you talking about the printed circuit board?
  • shreyasm89
    @shreyasm89-jGobVm • Sep 17, 2010
    @aj-No buddy...he is already aware of a PCB.In fact he expected to find a PCB inside but instead found a black polythylene-like material.
    @nenu-The small chip that you are mentioning is the microcontroller IC. Was that black material between the numeric keypad & the chip?
  • patsham
    @patsham-AsXMka • Sep 17, 2010
    you can show us the picture of that circuit so that we can help you.
  • nenuadwani
    @nenuadwani-pb4lOD • Sep 18, 2010
    shreyasm- you are ryt. I expected a pcb, infact i got a pcb based circuit also in other calculators. but the model i opened first didnt had a pcb. the whole circuit was on polythene just lyk it would have been on a pcb.
    i will try providing a picture of that circuit. no the ic is on the chip itself.
  • Van Helsing
    @van-helsing-nwELoN • Sep 21, 2010
    I was aware that a PLC (programmable logic controller) was a computer inside application, not vice versa. ๐Ÿ˜•
    The "all plastic" inside with embedded IC's under polimeric black glue drops is the china-way of making things cheaper. A PCB is made of polymer/glass fiber board with copper wiring layers. The plastic PCB (Poly Carbonate) or other, with carbon wiring layer is a cheaper more flexible way of making PCB's. And thinner too. The cost of a microprocessor or a digital integrated circuit is mainly connections and body. For very large production scale is cheaper to mount IC's directly on the PCB alas protected by a glue drop.
    Obviusly, under the drop you'll find gold wires connections to carbo-something circuit threads to an fro keyboards and LCD display, and a chip wich holds a microprocessor usually 4 bit wide, a RAM a ROM and an I/O logic as usual in a microcomputer. The ROM holds the software for making the calculator ... calculating. ๐Ÿ˜’
    Cheers...
  • nenuadwani
    @nenuadwani-pb4lOD • Sep 22, 2010
    I am thankful to all for clearing my doubts. Now I am clear about what I actually saw inside that calculator.
    Thanks a lot crazy engineers.
  • ITPROFESSIONAL
    @itprofessional-7OFia1 • Apr 6, 2023
    these all are PLC's
