Insert Coin - New Ray Solar Charger That Sticks To Window Panes
Guneet Khanuja
Guneet Khanuja
@guneet-khanuja-aX8fYa Oct 26, 2024
The 'Insert Coin' is a new concept that can revolutionize once it is started to be used worldwide. This concept needs sponsorship to start its production on a wide scale. Insert Coin is based on a very simple concept.
Most of the solar chargers that have been developed so far require continuous change in position of the charger with the change in position of the Sun. Also, there is no scope for proper window fixation. One of the biggest seller of solar chargers - the Amazon's Accessory Power's ReVIVE, is also far away from the ideal conditions. On the contrary, Ray Solar Charger has a lot of strengths as it is very flexible. It has LEDs mounted that keep the informing the user about the track of progress. Insert Coin is sufficient enough to full charge a cell phone. It is supported by USB cables that come along with the cell phone instead of wires , and this makes the Insert Coin very neat. The best part about the Insert Coin is its price! It is available at a price of just $ 40, which is far less than the price offered by other companies manufacturing solar chargers like the Accessory Power or the Lenmar.
This charger can be used anywhere, from your car to your home. It could charge up all gadgets like cell phones, iPods, etc. .This technology is being promoted to help the "green" effort. One can even place the device in the car and keep charging it without even running the car. Though charging with a solar charger takes time, this device is worth a buy.
