imaginary number in c++
maria flor
@maria-flor-8cAkif โ€ข Oct 23, 2024
could someone help me on what to input on C++ so that i can get the imaginary roots of a quadratic equation....
I really don't know what to do...๐Ÿ˜ญ
help me please..๐Ÿ˜•๐Ÿ˜•๐Ÿ˜ญ
thank you!!
  • vinci
    @vinci-e4PtMU Feb 25, 2012
    [โ€‹IMG]
    try this equation. let me know if it doesnt work still
  • silverscorpion
    @silverscorpion-iJKtdQ Feb 25, 2012
    Use a variable to indicate whether the delta (B[sup]2[/sup]-4AC) is positive or negative.
    Instead of
    pro = sqrt((b*b)-(4*a*c));
    here, use
    pro = sqrt(abs(B*B)-(4*A*C))
    And then, if delta is positive, use it as is. If delta is negative, just print an 'i' or 'j' along with the result, to indicate that the root is imaginary...
  • maria flor
    @maria-flor-8cAkif Feb 25, 2012
    vinci[โ€‹IMG]
    it doesn't work
  • maria flor
    silverscorpionUse a variable to indicate whether the delta (B[sup]2[/sup]-4AC) is positive or negative.
    Instead of
    here, use
    i just tried it but when i try to input an equation with imaginary roots.. it doesn't give me an answer...
  • maria flor
    Instead of
    here, use
    thanks for that but when i try to input an equation with imaginary roots.. it still doesn't give an answer...
  • silverscorpion
    After you have calculated delta, (variable "pro" in your program), calculate the individual roots in the following way..
    pro = sqrt(abs(B*B-4*A*C))
    if ((B*B-4*A*C) >= 0) {
        x1 = (-B+pro)/2*A
        x2 = (-B-pro)/2*A
        cout << "The first root is " << x1 << endl
        cout << "The second root is " << x2 << endl
    } else {
        real = -B/2*A
        imag = pro/2*A
        cout << "The first root is "<<real<<"+i"<<imag<<endl
        cout << "The first root is "<<real<<"-i"<<imag<<endl
    Try using this..
  • vinci
    you need value of of a,b,c ?i found that equation i posted here gives complex roots .
  • maria flor
    silverscorpionAfter you have calculated delta, (variable "pro" in your program), calculate the individual roots in the following way..
        x1 = (-B+pro)/2*A
        x2 = (-B-pro)/2*A
    } else {
        real = -B/2*A
        imag = pro/2*A
    Try using this..
    it still don't work... when i try to run it and input values with imaginary roots it suddenly return...
  • silverscorpion
    What is the input you are giving and what is the output?
    Give the full dump..
  • maria flor
    @maria-flor-8cAkif Feb 26, 2012
    here: when i input those numbers...it returns without giving any roots...
