can anyone tel me any algorithm(links to existing) for converting an image into a non readable text?.. i found some convertors available but i want to know how it works.any help on the topic would be appreciated.0
Dear guest, you must be logged-in to participate on CrazyEngineers. We would love to have you as a
member of our community. Consider creating an
account or login.
Member • Jan 22, 2012
You mean OCR or, non readable characters, what do you mean?subashreecan anyone tel me any algorithm(links to existing) for converting an image into a non readable text?.. i found some convertors available but i want to know how it works.any help on the topic would be appreciated.Are you sure? This action cannot be undone. -
Member • Jan 23, 2012
not ocr...i need some encoding techniques other than base64 encoding to convert an image into text...the text file should contain non readable characters which again onother side i should be able to convert into image...any efficient algorithm published?Are you sure? This action cannot be undone. -
Member • Jan 24, 2012
Ah!!! In that case, you can use Base64 as that is the best... Also try LZMA... 😀subashreenot ocr...i need some encoding techniques other than base64 encoding to convert an image into text...the text file should contain non readable characters which again onother side i should be able to convert into image...any efficient algorithm published?Are you sure? This action cannot be undone. -
Member • Apr 28, 2014
Read this post:subashreenot ocr...i need some encoding techniques other than base64 encoding to <a href="https://www.rasteredge.com/how-to/vb-net-imaging/image-converting/" target="_blank" rel="nofollow noopener noreferrer">VB.NET Image: Tutorial for Converting Image and Document in VB.NET Application</a> into text...the text file should contain non readable characters which again onother side i should be able to convert into image...any efficient algorithm published?
#-Link-Snipped-#Are you sure? This action cannot be undone.
