  • Icy Finger if Death - A Chilling Movie from BBC
    Ramani Aswath
    Ramani Aswath
    @ramani-VR4O43
    Updated: Oct 22, 2024
  • durga ch
    MemberDec 2, 2011
    I did not quite understand what was happening :-s. can someone who watched the video already elucidate?
  • silverscorpion
    MemberDec 2, 2011
    Oops.. The video is not up anymore. It's removed.
    Based on what I watched and understood, there is a water body. A stream of water flows into it, just like a river flows into the sea. That stream has a very high salt content.
    Because of that high salt content, the freezing point of water around the point where the stream flows into the sea is lowered (It's a colligative property).
    So, water freezes around the path where the stream flows into the sea, in a column of ice.
    Liquid water flows around the column, but the path where the salty water flows solidifies into an ice column and proceeds deep.
    Once it reaches the ocean floor, it starts engulfing all the fish and other organisms around in the icy sheath, freezing and killing them instantly.
    Pretty scary and chilling to watch, it was!! 😲
  • silverscorpion
    MemberDec 2, 2011
    The video is available #-Link-Snipped-#
    AdministratorDec 2, 2011
    silverscorpion
    😕 *trembles* Scary description it is.
    high salt content -> Does it refer to the DEAD SEA?
  • silverscorpion
    MemberDec 2, 2011
    Well, not necessarily.
    Colligative properties are properties of fluids that depend on the number of molecules of a substance present in a fluid, rather than the molecules themselves.
    So, when a solute (salt) is added to a solvent (water) to make a solution (brine solution), the freezing point of the solution becomes less than the freezing point of the solvent.
    By how much the freezing point decreases depends on the number of molecules of the solute in the solution. So, since it instantly freezes the water it comes into contact with, the salt content must be pretty high indeed.
    But then, the article mentions that the video was shot at Little Razorback Island, near Antarctica's Ross Archipelago. So, it's not dead sea. 😀
