  • i want help with my project "accelerometer controlled robotic arm"
    raaj90
    Member
    Updated: Oct 17, 2024
    Views: 1.1K
    i am making my final year project in electronics .my topic is accelerometer controlled robotic arm .i cannot proceed with circuit diagram and coding of it can any one help ??
    Hello Raj,
    Welcome to CE. See don't waste your time to find the ready code and circuit but try to find the circuit and give at least one or two try to make the code by yourself by this way you can acquire the knowledge which is useful to you in future.
  • narayana murthy
    MemberApr 20, 2011
    @gf: nice answer bro
    @raaj: hi raaj
    i think i am not right person to tell because as i am in 3rd year but i cant hold without saying
    the project given to you is on your interest am i right
    then why are you asking us to do your project as assembling and checking is not a matter of project because a well known kid can do it try to know components its required and know there properties and combine them
    if you got any problem feel free to ask because we are here to do that
    it may hurt you but it is a fact don't misunderstand me please
  • raaj90
    MemberApr 20, 2011
    i need tip about how to interface an acelerometer with any motor (to drive the arm)??
  • narayana murthy
    MemberApr 20, 2011
    i think you need controller to interface and control both of them or your accelerometer is having a controller?
    but on basis on this interfacing i think godfather may help you 😀 better than me
  • raaj90
    MemberApr 20, 2011
    what do u suggest ??
    shud i construct the arm or buy 1 ???
    )finance is also my concern in the project.)
    but i have lots of queries that which microcontroller should i use atmega16 or 32 and ?shud i directly interface the triaxis accelerometer with the microcontroller??
    i also need make this project wireless between the arm and accelerometer would that be possible????
    raaj90
    As per my knowledge you can't interface your ARM directly to Accelerometer but you have to take the data from the Accelerometer then according to change you have to drive the motor. i mean change in direction decides the motor movement X,Y or Z direction.
  • raaj90
    MemberApr 20, 2011
  • narayana murthy
    MemberApr 20, 2011
    raaj90
    yes i think you can for that you have to use some transmitter and receivers
  • raaj90
    MemberApr 20, 2011
    how many accelerometers will i require to control a 3 fold arm in four directions??
  • narayana murthy
    MemberApr 20, 2011
    raaj90
    i think it can be done using one because direction of arm depends on movement of motor
    hope i am right and clear
    raaj90
    Yes it is Possible why not check this topic #-Link-Snipped-# you can use that RF module for wireless communication.
  • raaj90
    MemberApr 21, 2011
    which software shud i use to simulate my project hardware??
    i have a design but i need to test it virtually first.
    i tried on "proteus" but it doesnt have accelerometer control.
    raaj90
    Hello Mate,
    I don't think the simulator have all the components you can simulate only some basic components for the accelerometer you have to test it practically and trial and error is the best way make one design debug it and find the solution if any. BUT i suggest to use the reference circuit given in the application note of every devices.
  • narayana murthy
    MemberApr 22, 2011
    raaj90
    i think all our softwares have a basic components why can't you try for building a accelerometer in that virtual design software
    narayana murthy
    How can he get the data virtually from accelerometer? I think its not possible to simulate Accelerometer in Simulator.
  • narayana murthy
    MemberApr 22, 2011
    godfather
    i am not good in simulators but i know only one thing in softwares like matlab we can connect the circuits and try to simulate them in my view they read the component properties and simulate according to them as accelerometer is also a made device but not a basic device it has his own components inside why can't we paste the circuit there and simulate them
    narayana murthy
    Yeah you can use MATLAB for some signal or Image processing.
  • narayana murthy
    MemberApr 22, 2011
    godfather
    yes so i am suggesting this may help in this topic we can connect them and test the output but i think its not so easy to simulate in matlab because many factors effect its simulations
  • raaj90
    MemberApr 25, 2011
    i have attached the layout developed by myself ..along with it i have provided the details in bracket. i just want to know if i am goin right ??
    are there any flaws in basic blocks?? or did i missed something???
    Good Preparation. I like this.
    There is one suggestion you can use RFM70 or RFM22 for RF communication.
  • raaj90
    MemberApr 25, 2011
    is it correct?? my block diagram,, shud i start working on it??did i miiss any thing
    raaj90
    Right now everything seems okey. You can start interfacing RF with Controller. once you done that then start interface with sensor and motors.
    Inshort divide your project into sections.
  • raaj90
    MemberApr 25, 2011
    why RFM70 or RFM22??
    the ones i have selected is not good???
  • xheavenlyx
    MemberApr 25, 2011
    Nice post. Raaj Good block diagram. If you can get things to work you might not need simulation.
  • raaj90
    MemberMay 1, 2011
    i got this diagram to interface servo with atmega32 but i cant figure out why the inductor used in it and wat is the supply that shud be connected to motor?? ...i have marked it wid red arrows
  • narayana murthy
    MemberMay 1, 2011
    nice work raaj do you tested it
  • raaj90
    MemberMay 2, 2011
  • xheavenlyx
    MemberMay 2, 2011
    Ok Raj here is the explanation:
    1. The Servo motor can be connected to the power source it specifies. For example if the motor runs on 5V you should connect it to that. If you have the development board then you would use the same supply thats going in to the micro controller.
    2. The AVCC is Analog VCC. It's used when you are using Analog to Digital converters for a signal. Then you would probably use a separate power source than the one powering your microcontroller and connect that to AVCC. For your application it would be connected to 5V (or normal VCC). You can keep it disconnected and see if the circuit works, if not then connect VCC (5V).
  • raaj90
    MemberMay 6, 2011
    ok i got it bt y that inductor and capacitor at pin 50 is used i didnt get that the whole system works just fine without the inductor also
    @Raaj~
    Well i am not able to see the images you have attached here. But i can say that if you take this circuit from any reference circuit then please go with all the component they have given and with that much value only otherwise it may work but sometimes you get some weird result to for protection of everything follow the standard Circuitry.
  • raaj90
    MemberMay 7, 2011
    @baron plz see i have attached the image here
    why the inductor used in it????
    [​IMG]
  • xheavenlyx
    MemberMay 9, 2011
    Ohk you are asking why Inductor and Cap on Pin #30 (AVCC). The LC combination forms an LC-Filter. It is required to keep the power line noise (and other high frequency noise) from disturbing your Analog pin readings. From our electronic classes we know
    f = 1 / 2 PI sqrt(LC)
    So larger the L and C value the smaller the pass frequency since we need to pass only DC (f ~= 0 ) we can use a good value of L and C like shown in the image, you will mostly be using a ceramic capacitor.
    I hope I have explained it, and please please correct me if I am wrong. Do your own research too. Look up "Bypass Capacitors" and "Filter capacitors" for more information!
  • raaj90
    MemberMay 9, 2011
    i got you bt ,while simulation in proteus all seemed to be fine even if i removed lc from circuit
    raaj90
    Dear Raj,
    As i said if possible then use the reference circuit. It might be possible that your circuit can work without some component but to get fully functioned project follow the standard they are using.
  • xheavenlyx
    MemberMay 10, 2011
    Yes it will still work. This is completely out of scope here but I came across a report that the LC filter on this particular model of Atmega controller is completely useless because VCC and AVCC were internelly shorted!!! It was a mistake by Atmel, and only on few batches.
    Yes, it will still work, you don't need it. But if you use the Analog to Digital pin you might need it then. Leave it disconnected, if the circuit works, all good. 😀
  • raaj90
    MemberMay 11, 2011
    thanx dats helpful
    raaj90
    thanx dats helpful
    @Raj ~
    Please do not use SMS text. Please !!
    and share your progress in this project with us. 😀
  • ecoo
    MemberJun 8, 2011
    raaj90
    Maybe this code help you. AVR processor work with AD7718 ADC and three ADXL203 accelerometers. I could attach schematic, but I need 10+ posts for attachments.
    // Inertial Cluster
    // Processor ATmega8
    // Clock rate 16 MHz
    // https://protoboardfab.com/
    #include <iom8.h>            // Declares the internal register addresses for ATmega8
    #include <inavr.h>            // Intrinsics for iccAVR
    // Function declaration
    void initPorts (void);                            // ATmega8 Ports init
    void shortDelay400ns (void);                    // Very short delay, approx 400 ns
    void shortDelay1mks (void);                        // Short delay, approx 1 mks
    void longDelay400ms (void);                        // Long delay, approx 400 ms @ 16 MHz
    void clearReadings (void);                        // Clear all readings
    void resetADC (void);                            // ADC reset
    void initUSART (unsigned char baud);            // USART initialization
    void initMasterSPI (void);                        // SPI initialization as a Master
    void transmitMasterSPI (unsigned char SPIData);    // Perform a SPI transmission
    void configADC (void);                            // Configure ADC
    void setChannel (unsigned char channel);        // Set ADC channel
    long ReadADC (void);                            // ADC reading
    long SetAndReadADC (unsigned char channel);        // Set & Read ADC at once
    void transmitUSART(unsigned char tdata);        // USART transmit
    void transmitSLIPUSART(unsigned char tsdata);    // SLIP transmit over USART
    // Selftest control
    #define    ST1            PB0            // Selftest pin for accelerometers and angular rate sensor
    #define    ST2            PB1            // Selftest pin for angular rate sensor only
    // ADC AD7718 control
    #define    DRDY        (PIND & 4)    // ADC Data Ready (active low, ADC master)
    #define    RSTADC        PD3            // ADC Reset (active low, ADC slave)
    // SPI
    #define    MOSI        PB3
    #define    SCK            PB5
    // UART
    #define    TXDPIN        PD1
    // AD7718 register model
    #define CommWR            0
    #define CommRD            64
    #define CommMode        1
    #define CommControl        2
    #define CommFilter        3
    #define CommData        4
    #define CommOffset        5
    #define CommGain        6
    #define CommIO            7
    #define CommTest1        12
    #define CommTest2        13
    #define CommID            15
    // AD7718 variables
    // ADC update rate for CHOP disabled
    #define updateRateNoCHOP1365Hz    3    // ADC update rate = 1365.33    Hz
    #define updateRateNoCHOP315Hz    13    // ADC update rate = 315        Hz
    #define updateRateNoCHOP59Hz    69    // ADC update rate = 59.36    Hz
    #define updateRateNoCHOP16Hz    255    // ADC update rate = 16.06    Hz
    #define BaseMode                147    // Chopping is disabled, AINCOM is unbuffered allowing it to be tied to AGND in single-ended input configuration, configured as a 10 pseudodifferential input, oscillator is not shut off, continuous conversion
    #define BaseControl                15    // Select input AIN1, enable unipolar coding, select the ADC input range as 0...+5 V
    // AD7718 channels
    #define accelerXch        0
    #define accelerYch        2
    #define accelerZch        5
    #define gyro1ch            4
    #define gyro2ch            9
    #define gyro3ch            6
    #define tempch            8
    #define GNDch            7
    #define accelerXnoFch    1
    //SLIP
    #define    SLIPEND        0xC0
    #define    SLIPESC        0xDB
    #define    SLIPENDESC    0xDC
    #define    SLIPESCESC    0xDD
    long accelerX;    // Accelerometer 1 (X-axis) current reading
    long accelerY;    // Accelerometer 2 (Y-axis) current reading
    long accelerZ;    // Accelerometer 3 (Z-axis) current reading
    long gyro1;        // Angular rate sensor current reading
    long temp;        // Temperature
    void main (void)
        __disable_interrupt();
        initPorts();
        clearReadings();
        initUSART(12);                                // 38.4 k  @ 8 MHz
        initMasterSPI();
        resetADC();
        configADC();
        //setChannel(accelerXch);
        setChannel(GNDch);
        while (1)                                    // Main loop
            accelerX = ReadADC();
            __delay_cycles( 10000 );                // Data synchronizer
            //transmitUSART(SLIPEND);
            //transmitUSART (0xAA);
            __delay_cycles( 800000 );    // Debug!!! 100 ms
            transmitUSART((unsigned char)(accelerX>>24));
            transmitUSART((unsigned char)(accelerX>>16));
            transmitUSART((unsigned char)(accelerX>>8));
            transmitUSART((unsigned char)(accelerX));
    void initPorts(void)                    // ATmega8 Ports init
        DDRB = 0;                            // All ports direction = input
        DDRC = 0;
        DDRD = 0;
        DDRB |= ( 1 << ST1 );                // Selftest pins = output
        DDRB |= ( 1 << ST2 );
        DDRD |= ( 1 << RSTADC );            // ADC reset and TxD = output
        DDRD |= ( 1 << TXDPIN );
        PORTB &= ~( 1 << ST1 );                // Selftest pins = 0 (no selftest)
        PORTB &= ~( 1 << ST2 );
        PORTD &= ~( 1 << RSTADC );            // ADC reset = 0
    void initUSART(unsigned char baud)                                // USART initialization
        UBRRH = (unsigned char)(baud>>8);
        UBRRL = (unsigned char) baud;
        UCSRB = (( 1 << RXEN ) | ( 1 << TXEN ));                    // RX, TX enable
        UCSRC = ( 1 << URSEL ) | ( 1 << USBS ) | ( 3 << UCSZ0 );    // Two stop bits, 8 bit
    void transmitUSART(unsigned char tdata)                            // USART transmit
        while ( !( UCSRA & (1<<UDRE)) );
        UDR = tdata;
    void transmitSLIPUSART(unsigned char tsdata)                    // SLIP transmit over USART
        if (tsdata == SLIPEND)
            transmitUSART(SLIPESC);
            transmitUSART(SLIPENDESC);
            return;
        if (tsdata == SLIPESC)
            transmitUSART(SLIPESCESC);
            return;
        transmitUSART(tsdata);
    void shortDelay400ns()        // Very short delay, approx 400 ns @ 16 MHz
        __delay_cycles( 3 );
    void shortDelay1mks(void)    // Short delay, approx 1 mks @ 16 MHz
        __delay_cycles( 12 );
    void longDelay400ms(void)    // Long delay, approx 300 ms @ 16 MHz
        __delay_cycles( 6400000 );
    void clearReadings(void)    // Clear all readings
        accelerX = 0;
        accelerY = 0;
        accelerZ = 0;
        gyro1 = 0;
        temp = 0;
    void resetADC(void)                // ADC reset
        PORTD &= ~( 1 << RSTADC );    // ADC reset pin = 0
        shortDelay1mks();            // Wait
        longDelay400ms();            // Debug!!!
        PORTD |= ( 1 << RSTADC );    // ADC reset pin = 1
        longDelay400ms();            // The oscillator will require the 300 ms start-up time
    void initMasterSPI(void)                                // SPI initialization as a Master
        DDRB |= (( 1 << MOSI ) | ( 1 << SCK ));                // Set MOSI and SCK output, all others input
        SPCR = ( 1 << SPE ) | ( 1 << MSTR ) | ( 1 << SPR0 );// Enable SPI, Master, set clock rate fck/16
    void transmitMasterSPI(unsigned char SPIData )    // Perform a SPI transmission
        SPDR = SPIData;                                // Start transmission
        while( !( SPSR & ( 1 << SPIF )));            // Wait for transmission complete
    void configADC (void)                        // Configure ADC
        transmitMasterSPI( CommWR | CommFilter );
        transmitMasterSPI( updateRateNoCHOP315Hz );
        transmitMasterSPI( CommWR | CommMode );
        transmitMasterSPI( BaseMode );
        transmitMasterSPI( CommWR | CommControl );
        transmitMasterSPI( BaseControl );
        while ( DRDY ) ;
    void setChannel (unsigned char channel)        // Set ADC channel
        channel <<= 4;
        transmitMasterSPI( channel | BaseControl );
        while ( DRDY ) ;
    long ReadADC (void)                            // ADC reading
        long ADCword = 0;                        // ADC current reading
        while ( DRDY ) ;
        transmitMasterSPI( CommRD | CommData );
        transmitMasterSPI( 0xFF );
        ADCword = SPDR;
        ADCword <<= 8;
        ADCword |= SPDR;
        ADCword <<= 8;
        ADCword |= SPDR;
        return ADCword;
    long SetAndReadADC (unsigned char channel)    // Set & Read ADC at once
        setChannel ( channel );
        return ReadADC ();
  • jobinvcm
    MemberDec 17, 2011
    I think for this much data transmission tranceivers are pretty useful try using CC2500 its really cool to work with that. if you want any help regarding that i can .... any way best wishes..
    jobinvcm
    CC2500 has some errata sheet and not able to make it working so i transferred to RFM70 and till date i have created more than 20 application based on RFM70. 😀
  • jobinvcm
    MemberDec 17, 2011
    If you need any sample codes i can provide.. I still think that CC2500 is pretty much efficient than other tranceivers.. It has huge frequency specturm
    jobinvcm
    Sure i will let you know but right now i found RFM70 equivalant to CC2500, But yes looking forward for other 434Mhz solutions from TI.
  • alem124max
    MemberDec 19, 2011
    hi,
    welcome to this forum site, here u can find lots of things. For your questions you should refer to your parents and friends.
  • alem124max
    MemberDec 23, 2011
    hi,
    I want programing codes for my accelerometer controlled robotic model and also want some tips how it will work and which programing language should i have to use.
    alem124max
    hi,
    How can anyone give you source code without knowing your application and hardware design? It's better that you share your code whatever effort you'd done and ask queries whenever you're facing problem rather than getting ready code, yes you can use some reference code. 😀
  • Suresh Manickam
    MemberDec 26, 2011
    you will need 3
