@valcon777-ZI5Xif • Apr 8, 2009
1- if one of the diode in the bridge rectifier shorts what are the possible consequences ?
2- discuss the effect of change in the value of filter capacitor used ? -
@crazy-cross-FTGeCY • Apr 8, 2009
valcon777I have two question :
1- what should be the PIV rating of diodes in the circuit ?
2- if one of the diode in the rectifier is opens , what should be the possible output voltage ?same wave is coming as output as inputted for agiven value of wt if it is full wave rectifier
i need help [ Basic questions in electronics ]
1- what happens to output voltage of a rectifier if the capacitor becomes very leaky ?
2- if the primary winding of the transformer in the power supply , what will you observe in the rectified output ?
3- the dc output voltage of the filtered rectifier is less thae it should be . what could be the problem ? -
crazy crosssame wave is coming as output as inputted for agiven value of wt if it is full wave rectifier
peak inverse voltage i laso need to know abt this dude its an exponentialvalue
@thebigk • Apr 9, 2009
Threads merged!
