Hybrid vehicle
ashwinsraj
@ashwinsraj-hD0dhW โ€ข Oct 26, 2024
hi, I am a mechanical engineering final year student. I wish to do my project on hybrid vehicles, probably series type. I want to know the following
1. Which type of battery is most economical to use?
2. Which motor DC series(brushed/brushless) or AC synchronous is
feasible?
3. I need to propel the vehicle to a maximum of 40km/hr so, what must be the power of the motor?
I have a budget of maximum Rs 80,000/- can you please help me to find solutions. Forgive me if I have made any mistake
๐Ÿ˜•
  • gohm
    @gohm-F3UUpP • May 21, 2009
    I've included my thoughts inline with your post.
    ashwinsrajhi, I am a mechanical engineering final year student. I wish to do my project on hybrid vehicles, probably series type. I want to know the following
    regular lead/acid cell 12v car batteries. however they are also the largest and heaviest
    feasible?
    I would suggest DC motor(s). 4 smaller hub mounted motors would be easier however a single traditional motor also works.
    what is the gvwr?
    ๐Ÿ˜•
  • ShrinkDWorld
    @shrinkdworld-WWdBBc • May 21, 2009
    hi
    Normaly batary are increase weigt of car. And according to me you can use it in car If you want to use it in bike then there is more dificulty in desigen for this battery
    My advice is keep your vehical Max. speed 30Km/h & use 4 speed gare or more it will increase your efficency
  • ashwinsraj
    @ashwinsraj-hD0dhW • May 21, 2009
    gohmI've included my thoughts inline with your post.
    Thank you very much this helps me a lot. But some doubt about the battery still. What about inverter batteries, some of my frinds advised me to use inverter batteries instead of automotive. Can you please site the differences between the two?๐Ÿ˜•
  • gohm
    @gohm-F3UUpP • May 22, 2009
    Totally depend on your budget and application. Inverter batteries would cost more and improve charge cycle in a hybrid application using pto from the i.c. engine though not sure if the life cycle cost would be benefitial since the two types are very similar. Not manditory though, especially in a project application.
  • krishthd
    @krishthd-iE5MwO • May 22, 2009
    invertor battery are better.coz they give more efficiency as they recharge
  • krishthd
    @krishthd-iE5MwO • May 27, 2009
    this will help you a lot for your requirements.............
  • Ashraf HZ
    @Ash • May 27, 2009
    krishthduydfclehgvliewuy ygweywehgkweyg kwjhvowieywejhkwejb this will help you a lot for your requirements.............
    Is that in the language of "cat-walked-over-keyboard"? ๐Ÿ˜€
    Im guessing you have problem with posting a link?
  • ashwinsraj
    @ashwinsraj-hD0dhW • May 28, 2009
    Thanks a lot.๐Ÿ˜€ Please answer me another doubt. Variable resistance contol or the use of a pulse width modulation motor controller would be better..??๐Ÿ˜•
  • Ashraf HZ
    @Ash • May 29, 2009
    PWM is much more better ๐Ÿ˜€ Variable resistance causes power loss, hence its not efficient for controlling motors.
  • ashwinsraj
    @ashwinsraj-hD0dhW • Jun 4, 2009
    Can anybody answer me a general doubt?๐Ÿ˜•
    The DC drive looks simpler. But most of the present day hybrids and EV's adopt AC drive systems... why is that so??
  • ashwinsraj
    The DC drive looks to be simpler. Inspite of this most of the present day hybrids adopt AC drive systems why is that so..???
  • jhbalaji
    @jhbalaji-AH60JJ • Jul 25, 2009
    Use Inventor Type Battery If Possible add a solar power too mate...
