Husk powered steam powered plant
slimes
@slimes-oKNhni • Oct 21, 2024
Hi to all CE'ans!
Please help regarding the husk fired steam power plant, what are the critical parts need to be focused?
Thanks!
  • sauravgoswami
    @sauravgoswami-UAfTlI • Apr 15, 2009
    Re: power plant
    which turbine you are using??? from generator onwards all power planst are similar
  • slimes
    slimes OP
    @slimes-oKNhni • Apr 15, 2009
    We are using impulse-condensing type turbine.
  • sauravgoswami
    and how you are suppose to run the turbine?? how much voltage it is expected to generate??how much voltage you want??
  • slimes
    slimes OP
    2500 kw gross, 440v.
  • sauravgoswami
    ok..so you will need a transformer for distirbution,and circuit breakers and relays for protection of you complicated components!!
