How would you modify a bicycle to make it more efficient?
This is my favorite topic and I can't stop discussing it infinite times. I'm still to find better answers.
I always believed bicycles could be modified to make them smoother & more efficient for the rider. To this day, the bicycles rely on gear & chain mechanism and there haven't been many changes (remarkable) in the way the system works (pardon my ignorance if there are developments already!).
Can we think of a completely new way of driving the bicycle which would still require manual efforts, but make it much more efficient than the current system.
Give it a serious thought, folks. [โ€‹IMG]
  • Ashraf HZ
    @Ash • May 22, 2009
    John Hopkins University had tested the chain drive's efficiency. They managed to get a a max of nearly 99%. Quite remarkable!
    Source -> <a href="https://www.sdearthtimes.com/et1199/et1199s13.html" target="_blank" rel="nofollow noopener noreferrer">ET 11/99: Pedal power probe shows bicycles waste little energy</a>
    I believe efficiency gains can be gained more from reducing rolling resistance from proper tires. Carbon fiber frames might be useful, but their prices are not really accessible to everyone at the moment.
    We might look into improving the chain drive's consistency rather than think of a completely new way.
  • Rohan_sK
    @rohan-sk-7ZbDkK • May 22, 2009
    The frictional resistance between the road and the tyres is exactly what is providing the turning moment for driving the bike.
    We can reduce the weight of the bike by using lighter materials for the framework, so that the inertia can be reduced, giving a better speed for applied effort. And the frictional force defeciet( ground contact) for driving the bike can be compensated by using a better tyre profile or a rubber with greater coefficient of friction, or wider tyres. This is because the reduction in the weight will decrease the normal reaction ultimately reducing the friction. The optimal value of this frictional resistance for turning the bike must be considered.
    The chain - sprocket combination is considered the best transmission media reducing the chances of slipping ( as in belts), but some other medium can be thought of.
    Also the air resistance caused by the driver can be reduced by modifying the sitting position ie bend a little while driving ( I think this is done in racing).
    Also we can use shock absorber or dampers which can store the shock energy (from bumps on the road) and convert it to some useful electrical impulse which can inturn be connected to a sysytem using this power to rotate the wheels whenever manual efforts are relieved due to fatigue or when the bike is under load say uphill drive or something like this. Its a very crude idea and needs much refining ,so Ceans can add more to it to make it more applicable.
  • gohm
    @gohm-F3UUpP • May 23, 2009
    That's easy Biggie, just add a motor! =)
  • krishthd
    @krishthd-iE5MwO • May 23, 2009
    ya u r right. all the modifications r being made to cars but not the bikes r concentrated.
    we can increase the eff. by better aerodynamics. I think we can attach an additional motor wich in combination with the engine gives better output.
    for this motor we shud use a more powerful battery wich can run it.
    Or we can use 2 motors for the 2 wheels of the bike wich run the same battery wich is more powerful.
  • Rohan_sK
    @rohan-sk-7ZbDkK • May 23, 2009
    I think , Big_K had suggested that the driving would still be MANUAL and not involve MOTORS!!
  • Ashraf HZ
    @Ash • May 23, 2009
    @ Rohan_sK
    I hope you did not misread my friction comment. I was talking about "rolling" rather than "frictional". Deformation may cause reaction forces that opposes the direction of motion. Hysteresis would also cause loss of energy through heat ๐Ÿ˜€ Thus, other than the tire profile you mentioned, the material of it also must be taken into account.
    I think we should all realize that efficiency means the how much of the energy power inputted is converted to useful energy. Adding a motor does make it easier to ride for us, but it doesnt necessarily add to its efficiency.
    If we do plan to add a motor, we'd need to get a highly efficient motor. Normal DC ones have efficiency of 50-60%. Also, from where would you primarily get the electricity from? P.V cells are still commercially below 30% efficient. And getting it from mains makes it dependent on a source.
    Thus, the assumption is.. how do we modify the bike to convert as much of OUR energy into useful power that allows us to travel over distances?
  • ShrinkDWorld
    @shrinkdworld-WWdBBc • May 23, 2009
    To increase efficency I will provide some essential sagestions=>>
    At first we can not reduce the friction between tyres & road surface At this moment it is already less. If we try to reduce It will take effect on grip of tyres.
    1) At frist remove all the unnecessary accesaries of cycle i.e mirror , mudgards,chain cover etc.
    2) After every month cheak the tenstion in the chain It will be gratly affect the efficency.
    3) you must have to use gears at weel & paddle
    4) It shude be well balance bearing in good condition
    5)Use proper pressure in tyres. or you can use tube less tyres
    6)The hight of seat shude be in proper height. It will be in position so that rider's become streat without lossing contact from paddle.
    7)YOu can use DC motor on top gear on dry cell (It will charge sepretaly from outside)
    plz comment on these instructions.
  • Rohan_sK
    @rohan-sk-7ZbDkK • May 24, 2009
    @Ash
    I think you got a bit confused with Rolling resistance and Friction.
    The Rolling Resistance that you are talking about is essentially the Frictional Resistance ( in Rolling) and the Friction you are mentioning is the SLIDING FRICTION. This Rolling Resistance is exactly what provides the Turning Moment. ( I hope I've interpretted you correctly this time, if not feel free to write again:smile๐Ÿ˜€.
    @Ash
    And I've already mentioned about the Material of the tyre ( refer : Providing rubber with a better Coefficient Of Friction)
    And The inclusion of motors is a good option, but it wont be remaining purely manual drive anymore, thats the reason I didnt include it.
    And its nice to see guys like you from Electronics having interest in Mechanical things๐Ÿ˜ Keep it up!!
  • Ashraf HZ
    @Ash • May 24, 2009
    Hm, I admit I'm even more confused ๐Ÿ˜›
    Just to see if we are on the right page.. we want to reduce the rolling resistance, yes?
  • Rohan_sK
    You're right, but simple class 12 physics seems strangely confusing!!!! ....
  • maxz
    @maxz-iHZPgv • May 24, 2009
    Hurm~!!!! I think the body of the frame have to be mobs a bit by mobbing it with some angle to reduce the air frictions against our body. As u see, if the raiders ride the bike at 60 degree bending down forward, the atmosphere pressure and force is against the raiders body. To reduce this kind of natural friction we shud lowered down the front part of the bike frame silghtly. If this may be possible, it will help the raiders to ride on bike more efficiently.
    This is all about guessing. Because i experince that when i ride on my bike, i feels that some kind of thing was pulling me backwards instead of forward. THen i was thaught that the air pressure is againt our body. thats why it cause me pull backwards a bit while i riding on my bike.
    Correct me if i'm wrong.
  • looknice
    @looknice-uKMc1Y • May 26, 2009
    Hi The Big K,
    I liked a lot your approach to the bicycle developments.
    I would propose another point of view.
    Let's think to the engine efficiency. I mean the human engine.
    If we give a look to the Eco-Shell Marathon we discover that with less than 20 Watth an internal combustion engine vehicle can run at 30 km/h!
    Very efficient.
    Perhaps is there something wrong between the man and the bicycle?
    My friend Francesco studied it and found that human engine is really very inefficient when interfaced to the pedal crank.
    His example "...how many attempts have been done on the sole stiffness of the cycling shoes without ever noticing that the foot on a hollow rod rotating around the malleolus can only รขย€ยœfallรขย€ย! " is really simple and clear.
    His BDS system try to reduce to the minimal this inefficiency.
    <a href="https://www.youtube.com/watch?v=tOyrm4tl2ck" target="_blank" rel="nofollow noopener noreferrer">BDS pro - YouTube</a>
    <The Big K: Adding the video to the post>
    [youtube]tOyrm4tl2ck[/youtube]
    Maximal efficiency and minimal energies that means efficiency in happiness.
    Sorry for my poor english.
    Ciao
    @thebigk • May 26, 2009
    Hi Look Nice,
    Thank you. It would be wonderful to have your friend on CE and share his designs. Would love to have a look at the BDS Pro.
  • gohm
    @gohm-F3UUpP • May 26, 2009
    Cool idea! other points of improvement could be to reduce loss due to friction. This would be in points like sprocket/chain, wheel bearings/hubs.
    gohmCool idea! other points of improvement could be to reduce loss due to friction. This would be in points like sprocket/chain, wheel bearings/hubs.
    Typically, I'd want something to store mechanical energy which can be used later when the bike is moving uphill.
    I could only think of a flywheel, but that's been ruled out because it'll increase the weight of the bike. A battery & a motor would be a good idea, however I'm not too sure if we're really being innovative here.
    Any newer methods, folks?
  • ShrinkDWorld
    @shrinkdworld-WWdBBc • May 26, 2009
    To Big k=>
    we can use spring but it is lightly heavy. But instead of it we can use dry cell
    @gg_gaurav: Yep, anything that you think would be useful.
  • Rohan_sK
    @rohan-sk-7ZbDkK • May 26, 2009
    @ Big_K: I had a similar thought of storing the mechanical effort/energy and use to power the bicycle when the driver is tired or on an uphill traverse. ( I have already mentioned in my first post on this thread itself, about using a system with suspensions in the form of shock absorbers which can use the shock energy from the bumps or pits on the road and convert this energy into some electrical impulse which can be used to charge a small battery. This battery can power a small motor which can drive the wheels on the uphill terrain:smile:.)
    Another way to do the same thing would be to use small fans on suitable locations on the frame where the wind flowing by ( due to bicycle motion) can be utilised to run the fans which inturn can rotate a small generating device. The amount of electrical energy ( though small) can be ued to charge a battery ( though the elctrical energy produced in unit time may seem small, it is considerable that the driving time will be relatively longer than the time span for which this power is required ie for uphill ride or when the rider is tired), this can charge the battery during most of the normal mode riding with small inputs at a time. This can again power a motor which will couple to the rear wheel drive and supply the extra drive force needed to ride the bicycle on an uphill terrain.
    There can be a set of 4-6 fans placed at suitable locations on the frame in the front as well as sides, and connect them to the generator which will be wired to the batteries. The batteries connect to the motors which will be coupled to the driving wheel through a set of small gears.
    The only point of reconsideration here is the weight to power ratio, as the system with battries, motor, wiring, gears( though all small specs) will add to the weight of the bicycle which is undesirabe. But it can be worked out.
  • g_rakesh2
    @g-rakesh2-CVEauh • May 26, 2009
    Innovations in bicycle are always continued from when its invented, in first phase it was a single wheel and there after alot of changes have made in desogn to increase the performance.
    The innovative rotor pedal system continues this evolution by utilising independent cranks that are not aligned at a fixed 180' to eliminate the "dead point" that occurs when conventional pedals are vertically positioned.Anyone who has tackled a very steep hill on a bicycle will understand the concept of a dead point.
    [โ€‹IMG]
    You always find that the moment at which you are forced to get off the bike and walk is when you are at the top of the pedal stroke - this is because at this dead point the rider has the least mechanical advantage with neither leg able to transmit any power. So if heading uphill, with no momentum to compensate, you find yourself getting out of the seat to increase leverage at this dead point.
    The rotor system solves this problem by using cranks that never allow one pedal to coincide at 180 degrees to the other. The independent cranks that are synchronised by means of an exocentric axel and two rods, which vary the transmission ratio during the cycle and prolong the power stroke phase for a more efficient transfer.
    What all this means in real terms is that by the time one crank is at the bottom of the stroke and in the six o'clock position, the opposite crank has been accelerated through to the one o'clock position and has already started the power stroke phase. In addition to increasing efficiency, traction and maintaining a smoother cadence, the rotor system reduces the risk of knee injuries and tendonitis that are attributed to the leg pushing on the upper dead point.
    According to the manufacturers, tests on the rotor have demonstrated a real increase in power of up to 16% (equivalent to an average advantage of 3 minutes in an hour), and a resultant reduction in lactic acid and cardiac effort.๐Ÿ˜
  • g_rakesh2
    what if bicycle built with bamboo.
    Its durable, strong and flexible and light wieght too.
    for more information go through this..
    #-Link-Snipped-#๐Ÿ˜๐Ÿ˜๐Ÿ˜
  • ShrinkDWorld
    @shrinkdworld-WWdBBc • May 27, 2009
    g_rakesh2==>>
    Nice idea!!!
    Rohan_sK==>
    good Idea. But we can not get more power from that fan Because if we tru to get more power It will increase resistanc.But it is usefull While in parking also.
  • Rohan_sK
    @rohan-sk-7ZbDkK • May 27, 2009
    Yes I am aware of the induced drag due to the fans , but the blades would be designed with aerodynamic considerations and the blade profiles will be in accordance trying to minimize the drag.
    These are all the real time practical design issues which need to be actually tested.
    Lets have some more ideas and innovations coming in from everyone!!
  • aprhockey
    @aprhockey-6HK03E • Feb 25, 2010
    g-rakesh2: I looked into the Rotor pedal system and it turns out that there is no significant advantage to using them.
    #-Link-Snipped-#)
    Another innovation by Rotor is the q-ring (an elliptical chainring)... however, I am skeptical of these also. They are designed so that when the pedals are at the dead point, there are fewer gear teeth to make it a faster transition back to the power stroke position.
    It'd be awesome if this thread was brought back to life
  • satanas
    @satanas-wIiiPN • Feb 27, 2010
    Hi all,
    Bicycles should be manually, including motors is a bad idea..else we would call it a motorbike.. am happy with my bicycle,just that it's a bit heavy. so i really think that if we want to have a more efficient ride, we need to consider lighter materails for construction and the profile or design (the frames).. Guys, if you mean 'aerodynamics' is relative to the rider's posture think also about your HEALTH (bending your spine!).. i will go for profile redesign (including aerodynamics kits).. Anyway, i think we should all invest our thoughts on how to reduce drag force first!!
    regards,
    Satanas
  • gohm
    @gohm-F3UUpP • Feb 27, 2010
    rider position to maximize power efficiency & center of gravity is a good idea in addition to reduced weight and friction. How about adding power via using arms as well to drive the bicycle?
  • aprhockey
    @aprhockey-6HK03E • Feb 27, 2010
    I think the key to making the bicycle more efficient is not to necessarily reduce lost energy due to friction (other than aerodynamics, there's not much left to reduce this), but to capture the lost energy and put it back into use.
    It was mentioned earlier that we could capture lost energy from the suspension in mountain bikes. Students at Georgia Tech used this idea to power safety lights in 2007, but maybe the energy could be used to help accelerate the bike (even if its not much energy). I'm sure it's worth looking into.
    When it comes to the idea of using both arms and legs, i think we're on the right track here, however, steering would be difficult if the hands were occupied.
    I strongly agree that reducing drag due to air is important, but we must keep in mind that the bicycle is so great because of its practicality and relatively low price compared to other forms of transportation. The bicycle has reached a record of 81 mph, however the rider can't even put their feet down because they are completely enclosed, which is not practical.
  • satanas
    please, first specify what do we want to achieve here?? speed or comfort or both? and is it for sports bicycles-competition- or those you use to go to the sea with your friends and give a ride to your beautiful gfs ๐Ÿ˜‰ ???
    Regards,
    satanas
  • aprhockey
    @aprhockey-6HK03E • Feb 28, 2010
    I may be thinking about this differently than others. I was thinking of how to make the average bicycle more efficient for the average person using it to commute. So, I guess I am thinking about modifying the bike for more efficient transportation.
    This probably makes it more difficult also, because the bicycle still needs to be practical and comfortable (easy to get onto, easy to store, easy to move around in traffic would help, and easy to fix).
    Perhaps there would be a way to capture the thermal energy the body creates and use that to power a small motor. Also, would the concept of regenerative braking be feasible (I really don't know anything about regen. braking). Anybody have ideas on that?
    For aerodynamic efficiency, I think that is the purpose of the recumbent bicycle. The rider is not in an upright position, so less body is exposed directly to the air. A bicycle with the body in prone position has been attempted, however, I think it's a very dangerous riding position, and I think it would be difficult to turn in tight spaces (in traffic).
  • arjunoids
    @arjunoids-fU9dJ4 • Mar 2, 2010
    tips to improve efficiency
    1. keep the air filter always clean. if necessary install a secondary.
    2. keep the tyre pressure to the maximum prescribed limit. (be careful, you may end up having a back pain over a period of time)
    3. use high octane petrol.
    4. keep the "idling" to as minimum as possible.
    5. check the the driving chain tension & also keep it well lubricated.
    6. do not, suddenly rise the accelerator.
    7. ride at optimum speed.
    8. service your bike regularly.
  • satanas
    @satanas-wIiiPN • Mar 2, 2010
    Hi,
    does this include bike also?? bike and bicycle are not similar..
    well, we did a project on increasing safety in kids bicycles. its an automatic braking system, actually a speed limiting system. it prevents the kid from riding his/her bicycle at a higher speed than a preset speed (say 30km/h).. just some minor changes without affecting comfort and weight..
  • aprhockey
    @aprhockey-6HK03E • Mar 2, 2010
    To arjunoids: I think we're talking about two different things. We'd like this thread to stay on bicycles its quality of having a low environmental impact.
    About my idea of capturing body heat... i don't think it's really feasible. MIT is developing a device that uses the thermal energy the body creates, however, it can only capture 100 microwatts or so.
    Could magnets be of use in anyway?
  • satanas
    @satanas-wIiiPN • Mar 5, 2010
    hmmm.. you want to the magnet to rotate the wheels?.
  • aprhockey
    @aprhockey-6HK03E • Mar 5, 2010
    well, magnets could easily be used to power lights on the bike using the concept of magnetic induction. If a couple magnets are placed on the spokes, when they pass an electric circuit it induces a current.
    Could the magnets be used to rotate the wheels? maybe if there were magnets around the rim and some placed on a fender so that as the magnets on the rim approached each magnet on the fender an attraction would accelerate the wheel forward. does this sound like it would work at all? I feel like this is trying to make a perpetual motion machine.
  • Vega
    @vega-Ic42ds • Mar 5, 2010
    Use of radium reflectors at back and front side of bicycle would enable other vehicles to see it. The light from vehicles will be reflected fitted to bicycle and help spotting bicyle in dark.
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Mar 5, 2010
    VegaUse of radium reflectors at back and front side of bicycle would enable other vehicles to see it. The light from vehicles will be reflected fitted to bicycle and help spotting bicyle in dark.
    I guess that is already available with latest bicycles.
  • Vega
    gaurav.bhorkarI guess that is already available with latest bicycles.
    Maybe! I don't know as I have not driven bicycle for long time.
  • 2010mayan
    @2010mayan-gdx1YL • Mar 5, 2010
    In the pedal crank we get the best mechanical advantage , only when the crank is at horizontal position. at other positions leg power is not utilised fully.
    A push down pedestal with rack & pinnion arrangement to convert downward motion in to rotary motion to drive the wheels thro chasin drive may result in a better mechanical advantage.
  • aprhockey
    @ 2010mayan: That may work. Do you mean instead of moving your legs in circular motion it would be more like pushing your feet alternately straight down? Would each foot move independently of the other? It would be interesting to look into it to see if it actually increased efficiency. It might be a bit tricky to design.
  • Ashraf HZ
    @Ash • Mar 5, 2010
    gohmHow about adding power via using arms as well to drive the bicycle?
    Yeah, maximize power throughput. How about using our head too? The nodding motion can at least power the safety lights ๐Ÿ˜›
  • Vega
    2010mayanIn the pedal crank we get the best mechanical advantage , only when the crank is at horizontal position. at other positions leg power is not utilised fully.
    Good idea! But I have couple of questions.
    In your design, how do you intend to bring the lever back to its top position? by leg pulling it upward or a spring or another power for it or other leg lever going downward will cause first one to come upward?
    What about its ergonomics?
    The existing circular motion gives good exercise to all leg muscles? What about this advantage in your design?
  • 2010mayan
    @2010mayan-gdx1YL • Mar 14, 2010
    Adding a spring to bring up the pedal may consume more power while pushing down. The two pedals are to be linked in such a way , when one pedal goes down other one will come on its own.
  • Vega
    @vega-Ic42ds • Mar 14, 2010
    2010mayanAdding a spring to bring up the pedal may consume more power while pushing down. The two pedals are to be linked in such a way , when one pedal goes down other one will come on its own.
    Yeah, something like crank, connecting rod and piston mechanism. Here there will be 2 pistons connected to two opposite end of crank by two connecting rods. Here pistons are peddles.
  • Salvatore Cosenza
    @salvatore-ZowYnw • Feb 20, 2011
    This is to inform You about the world-wide challenge which has been launched for the building of new human powered application that is going to break any human power (eg.: for climbing up-hill) and speed record.
    For reason of mere convenience, pedaling in HPAs and all the cycling world (up-right, standing position bicycles comprised, as well) will get its change, either for normal-dotated and disabled persons. Best advantage to Your Company isn't to delay upgrading, as least among other companies in the world.
    The present email gives me also, the opportunity to open to alliance with other companies (also envolved in outsourcing), Venture Capitalist and Business Angel for the constitution of multinational group aiming to replace all the bicycles in the world in the shortest time, as well as applying the patented system in all HPAs.
    Please give a glance to the following link:
    Regards.
    P.S.: You may also check:
    <a href="https://www.freepatentsonline.com/EP2014545.html" target="_blank" rel="nofollow noopener noreferrer">System for transforming rectilinear motion to circular motion - COSENZA SALVATORE</a>
  • emmawotson
    @emmawotson-nkzz7N • Feb 21, 2011
    hey i also confused it is more complex. if you want the simple explitation then just visit the site:
    charusat.blogspot.com
  • Salvatore Cosenza
    @salvatore-ZowYnw • Feb 22, 2011
    emmawotsonhey i also confused it is more complex. if you want the simple explitation then just visit the site:
    Sorry You havenรขย€ย™t understood the documentation of patent application I have filed (if You have taken the time to study it!). My patent counselor understood it, though they have acted some correction upon it.
    But if You have not been reading at all the documentation, I advice to do it through the links You find by this search:
    <a href="https://www.google.it/search?q=EP2014545&hl=it&rlz=1C1AVSW_enIT376IT377&prmd=ivns&filter=0" target="_blank" rel="nofollow noopener noreferrer">EP2014545 - Cerca con Google</a>
    Or just by typing the patent number as a key word in Your search engine:
    EP2014545
    Besides all, I have other characters of novelty to add to the present state of art; and I canรขย€ย™t waste the chance to file new patent applications when I talk freely with potential competitors.
    When I get sponsor partners I might file-up new patent application more clear and concise, with other novelty characters.
    So if You want further help You might get it as a sponsor partner of mine, by my patent counselor under un-disclosure agreement. Youรขย€ย™ll be asking them the conditions to work it out in partnership association with me, as this matter belongs to their professional task.
    Sincerely Your!
    P.S.: Email me to know my patent counselor address.
  • ramaseenu
    @ramaseenu-TMfWXV • Mar 19, 2011
    A cycle with bevel gear at gear axial inclination used for transmission of power from pedal to wheel .This may be a sustitute for chain sprocket mechanism.I may send detailed drawing if contacted at ramaseenu @ rediffmail.com.
  • Gurjap
    @gurjap-blPmg9 • Mar 11, 2012
    HA!! finally found the thread that led me to be a CEan in the first place.
    Anyway, I thought I had this brilliant idea of replacing the whole chain-drive set with a hydraulic power transmission system. It would have automatic gearing and power regeneration. I was going to use pedal power to run a pump, which would then pressurize a fluid to drive BOTH the rear and the front wheel by using a hydraulic motor on each of those (using hydraulics makes it easy to do that). It would be able to store power: when you pressed on the brakes, the pressurized fluid would be directed to a cylinder fitted with a heavy spring-loaded piston, which would be raised up, storing energy. When you released the brakes, this piston would pump back pressurized fluid back into the system.
    But as is wont to be with most of my ideas, someone already did it. And made a wikipedia page about it. Just awesome.
    But not a bad little project to do.... just for fun.
  • ISHAN TOPRE
    @ishan-nohePN • Mar 14, 2012
    #-Link-Snipped-# This cannot be done to improve efficiency. The efficiency of cycle wont change. It will rather reduce with Hydraulic system installed.
  • Gurjap
    @gurjap-blPmg9 • Mar 16, 2012
    #-Link-Snipped-#.. really, will it? Fluid frictional losses are inherent in any fluid system, just as other kinds of friction losses are inherent in others. And I am regenerating lost braking power!
    Maybe I did not express myself too clearly. I did make a dwf file on Automation Studio, courtesy NITJ automation lab workstation. Here it is.
    https://docs.google.com/open?id=0B8XQjy5Ph3X4VnZodjVVVVdSaDJFZTFpZVJ5b2Y2Zw
  • ISHAN TOPRE
    @ishan-nohePN • Mar 16, 2012
    Gurjap#-Link-Snipped-#
    #-Link-Snipped-# does that file need a particular format? It says not found #404 error
