Hi, I have a problem these days. I have a PC with two internet connection. Now I want to use both internet connection simultaneously. I want to use one connection for downloading and another for browsing. I searched a lot but did not find a free (open source ) and proper software. Kindly help me guys.0
Member • Mar 5, 2012
can you explain your set up indetails??
I am interested to know if you have 2 NICs or you have router to 2ISPs and then a single NIC on your computer.. or any other useful information?Are you sure? This action cannot be undone. -
I have one WiFi and One 3g USB Modem Connection. Now I wanted to use both of them, but for different use, i.e. one for downloading and one for browsing.Are you sure? This action cannot be undone. -
Member • Mar 6, 2012
I THINK IS NOT POSSIBLE TO USE BOTH CONNECTIONS IN ONE SYSTEM..ANY WAY U CAN USE ANY ONE CONNNECTION FOR BOTH(DOWNLOADS OR BROWSING ) OR U NEED TO HAVE TWO PC'S TO USE 2 CONNECTIONSAre you sure? This action cannot be undone. -
Administrator • Mar 6, 2012
#-Link-Snipped-#, avoid using ALL CAPS.Are you sure? This action cannot be undone. -
OK ( THIS IS LAST )Are you sure? This action cannot be undone. -
Member • Mar 7, 2012
I found a program named ForceBindIP [#-Link-Snipped-#]. But it is not working on my Windows 7 64 bit. 😔Are you sure? This action cannot be undone. -
^^ From that url,
Due to the APIs required, ForceBindIP will only run on Windows NT/2000/XP/2003. It will not function on Win9x/WinME.
I think win7 might not be supported too.Are you sure? This action cannot be undone. -
This is an experimental suggestion:
If you want two connections but don't want to use two different computers, try simulating two machines.
I mean to say, run an OS from a virtual machine and use that to handle downloading
( To be crazy, install win xp inside win 7 AND use ForcebindIP in the virtual win xp ^^)
Gotta try and see if it works!Are you sure? This action cannot be undone. -
Member • Mar 8, 2012
eternalthinker thanks for your reply, but i don't want to use virtual system technique. As I want save my system resources. I already know this.Are you sure? This action cannot be undone. -
Okay!
There are also some very very light versions of linux which you can run inside windows without a virtualization software. I doubt to what extend the environments would be isolated. Anyway you might want to try that too 😀Are you sure? This action cannot be undone. -
ya sure, I am interested for this. Can you tell me some of them.Are you sure? This action cannot be undone. -
Member • Mar 9, 2012
Check out Damn small linux : #-Link-Snipped-#Are you sure? This action cannot be undone. -
This one is really old and now a better and small linux have come... Search and check it out...eternalthinkerCheck out Damn small linux : #-Link-Snipped-#Are you sure? This action cannot be undone. -
Member • Mar 10, 2012
#-Link-Snipped-# Cool! Which one is that?Are you sure? This action cannot be undone. -
Not sure buddy.. Will search and say... 15 MB Linux... 😛eternalthinker#-Link-Snipped-# Cool! Which one is that?Are you sure? This action cannot be undone. -
ok, there is this idea.
Get a wireless router which supports3G modem read here :#-Link-Snipped-#
this will enable you to share internet between your wireless eithernet and 3g modem, but I am not sure if it will allow you to filter the packets
You can connect your ethernet and usb to this router and share itnernet. check it outAre you sure? This action cannot be undone. -
Member • Mar 11, 2012
Thanks everyone for your reply. My main aim is to use both internet connection without spending more money and laptop resources.
For now I came up with a temporarily solution. I am using #-Link-Snipped-# for creating a proxy server (for 3g usb modem). By using this I am able to download on utorrent via proxy and browsing via wifi.
But that proxy sever is not working with any other applicaton (IDM, or any web browser).Are you sure? This action cannot be undone. -
Member • Mar 28, 2012
Kishan GuptaHi, I have a problem these days. I have a PC with two internet connection. Now I want to use both internet connection simultaneously. I want to use one connection for downloading and another for browsing. I searched a lot but did not find a free (open source ) and proper software. Kindly help me guys.
u can try downloading in an OS virtually using vmware and can simultaneouly try surfing from the main OSAre you sure? This action cannot be undone. -
Kishan GuptaThanks everyone for your reply. My main aim is to use both internet connection without spending more money and laptop resources.
I'm curious reading the question. did you find a better solution?Are you sure? This action cannot be undone. -
Member • Mar 29, 2012
No, not yet. Still using same proxy server for downloading on utorrent.ypagrawalI'm curious reading the question. did you find a better solution?Are you sure? This action cannot be undone.
