How to work in Cloudsim?
nitishchopra2002
@nitishchopra2002-Q4CixT โ€ข Oct 23, 2024
hello everyone
i am looking to work in cloudsim software for scheduling . i installed jdk and then netbeans , after that i followed
this link instructions . I m still unable to run examples as per the instructions given by the this . error coming is the MISSING MAIN CLASS . can anybody help ?
also i want to know how to use cloudsim , i mean are we required to modifications in cloudsim given examples to implement own scheduling alogrithms? kindly explaina bit .
thank u
  • Reya
    @reya-SMihdC • Jun 28, 2012
    Did you install cloudsim with netbeans properly? Can you upload the screenshot here?
  • nitishchopra2002
    @nitishchopra2002-Q4CixT • Jun 28, 2012
    sorry. cannot upload screen shots now. have u worked in cloudsim? its my first time. what knowledge is requred to use cloudsim or to implement new scheduling techniques in cloudsim.
    basic concepts of java programming or deep programming in java? or something else too?
  • Reya
    Knowledge about Basic Java programming,cloud computing,some programming IDEs like Eclipse is sufficient to work on cloudsim. Sorry, I've not worked on cloudsim.
    This would answer all your questions- #-Link-Snipped-#
    If you have any doubt regarding the implementation, feel free to ask here.
  • nitishchopra2002
    thank you so much
  • sandeep varma
    @sandeep-varma-UzlZlq • Dec 21, 2012
    me too followed the above instructions but got the error message while running CloudSimExample1:
    java.lang.UnsupportedClassVersionError: org/cloudbus/cloudsim/provisioners/PeProvisioner : Unsupported major.minor version 51.0
    at java.lang.ClassLoader.defineClass1(Native Method)
    at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
    at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
    at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
    at java.net.URLClassLoader.access$000(URLClassLoader.java:56)
    at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
    at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:276)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
    at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
    Exception in thread "main" Java Result: 1
    BUILD SUCCESSFUL (total time: 0 seconds)
    .Can anyonehelp me please
  • rahul69
    @rahul69-97fAOs • Dec 22, 2012
    Looks like there is a mismatch between ur jdk and jre. Which version of jdk u r using?
    I have seen people with java7 facing this problem.
    Try reinstalling jdk and jre so that both have same version.
    ๐Ÿ˜€
    Hope it helps!
  • vartta siyal
    @vartta-siyal-H5tYAa • Jul 1, 2013
    nitishchopra2002hello everyone
    thank u
    hi nitish,
    i m also getting d same error and working on d same project.
    if u get ur error resolved, kindly help me. or send ur contact so dt i can contact u. my email- #-Link-Snipped-#
    or if any one can help plz ......
  • hajar
    @hajar-7WgmuS • Jun 1, 2015
    hello
    please check this .it can help and guide you
    <a href="https://installwithme.blogspot.com/2014/10/how-to-install-cloudsim-in-windows.html" target="_blank" rel="nofollow noopener noreferrer">Install With Me !: How to Install CloudSim in Windows (in 3 easy steps)</a>
    <a href="https://mapurva.files.wordpress.com/2013/01/install-cloudsim-with-eclipse.pdf" target="_blank" rel="nofollow noopener noreferrer">PDF</a>
  • maryam87a78
    @maryam87a78-n36QTY • Jul 9, 2015
    hello
    i have a program and i want write it in cloudsim ,i installed cloudsim on netbeans but i cant registery my classes with cloudsim, classes.
    can U help me please?
    @abrakadabra • Jul 16, 2015
    Tagging #-Link-Snipped-# for help here.
  • rahul69
    @rahul69-97fAOs • Jul 27, 2015
    maryam87a78hello
    I am not sure what you meant by 'registry my classes' but if you are facing issue after installing cloudsim, you may include it as a project and extend the cloudsim classes to your own new classes.
    Hope it helps.
  • Cathrine Selvista
    @cathrine-selvista-tZhfgO • Mar 9, 2016
    Hi all,
    How can i integrate occi4java with cloudsim?
    please help...
    Thank you in advance
  • Cathrine Selvista
    Hi all,
    How can i use the cloudsim with the occi4java ?
    Please help me out of this...
    Thankyou in advance
