how to slow down an electrical rc car motor ??
Q8uwait
@q8uwait-IgViXB โ€ข Oct 26, 2024
Hello,
i am doing a voice activated voice control.
i have an rc car .. i would like to know how can i decrease the speed on the motor ,, cause the response i have with the voice circuit is slow.. and the car is way fast..
thanks
  • sauravgoswami
    @sauravgoswami-UAfTlI • Apr 9, 2008
    Hi!!,buddy you better use a gear system,or set the speed such that it will increase/decrease in synchronisation with ur voice
  • eccentronix
    @eccentronix-n19Tvv • Apr 13, 2008
    how are you controlling the wheels? PWM?
  • desijays
    @desijays-2SqnUc • Apr 17, 2008
    Q8uwaitHello,
    thanks
    Let me get this straight. You're trying to control the speed of you're motor using you're voice.
    I take it that you are try to give english commands to the voice detecting circuit which will pass that info to the controller which in turn controls the motor. Well, Im not sure what kind of voice commands you are using.
    But if you want to control a motor, PWM is the way to go as the poster above has mentioned.
  • sanih
    @sanih-ksvCvd • May 2, 2008
    pwm is better.
    you can slow down it with pulses for example :
    2/3 high 1/3 down.
  • xheavenlyx
    @xheavenlyx-CbvN62 • May 6, 2008
    can you control a normal DC motor with PWM? can u post a rough crkt idea here?
    555? or a dedicated PWM generator has to be used?
    I am soo weak on the motor front and its so important as a hobby!
  • Ashraf HZ
    @Ash • May 6, 2008
    I believe a 555 timer can be used, but an easy way would be using a microcontroller with a PWM output, via a motor driver ๐Ÿ˜€ Response time is pretty good.
    Of course, if you want to decrease the motor speed indefinitely, using gears (plastic, for an RC car) would suffice ๐Ÿ˜‰ Its a bad idea to decrease voltage to the motor directly as they have a minimum operating voltage.
  • arunbasillal
    @arunbasillal-7szUxa • Jul 6, 2008
    add a pot to the circuit and adjust the speed to your wish.
    Its that simple..
  • xheavenlyx
    @xheavenlyx-CbvN62 • Jul 7, 2008
    Yea but a Pot reduces the Voltage which reduces the speed (and also reducing the current) and then the torque gets screwed; also, you loose a LOT of power which is hell if you are on a battery. I had read somewhere about the H-bridge but never got around implementing it (and forgot if it has variable speed).
    till now, on forums, H-bridge is the most used, but dont know much about it. Anyone?
  • arunbasillal
    @arunbasillal-7szUxa • Jul 7, 2008
    Yep. Pot is a simple approach. it just creates wastage of power, but the thing gets done.
    can anyone tell me what a H-Bridge is..?
  • Ashraf HZ
    @Ash • Jul 7, 2008
    I believe the waste of power might factor in too much, because the RC car runs on batteries ๐Ÿ˜‰
    H bridges are effectively used to control the direction of the motor rotation. There is no "fixed" design, though.
    I recommend you use motor drivers (like the simple L293), and use the PWM (Pulse Width Modulation) as the input to control the speed. The PWM can be generated by a microcontroller.
  • gohm
    @gohm-F3UUpP • Jul 8, 2008
    Does your RC car currently have an esc?
  • arunkumarr
    @arunkumarr-xT52wy • Jun 26, 2009
    Check this site for details description of DC Motor control
  • adam402
    @adam402-3PFfG9 • Sep 26, 2012
    is sanih said that you can slow down it with pulses for example :
    2/3 high 1/3 down. where from you get it . now i am using Ghost 1/18 Scale Electric RC Truggy 2.4GHz. this Ghost
    <a href="https://www.nitrotek.se/radiostyrda-bilar.html" target="_blank" rel="nofollow noopener noreferrer">RC Bilar | Kรถp Online Hos Nitrotek</a>
    is a lot of fun and an excellent choice for both beginners to the RC hobby and also to experienced racers to add to their collection. but i am interested in yours. can you share where from you get it. .
  • grsalvi
    @grsalvi-7IhIh1 • Sep 29, 2012
    using h-bridge of semiconductor switches which switch efficiently.
    You can control how much power goes to motor by controlling switching on-off of semiconductor switches,which is done by controlling their firing pulses.(done by microcontroller)
