  • How to shut down machine in different ways?
    ilavarasan
    Member
    Updated: Oct 26, 2024
    how to shutdown machines in different ways?
    AdministratorJan 11, 2012
    ilavarasan
    That's now how a computer science engineer would ask a question. Why not provide the details of the machine you wish to shut down and what you're exactly trying to do. For above question, I'd simply reply "Just Pull The Plug Off From The Socket", but that won't really help, right?
  • Dancer_Engineer
    MemberJan 11, 2012
    The_Big_K
    LOL. 😁
    ilavarasan
    There is a Windows Registry trick to disable the Shutdown command, by which you can never shutdown the system; unless you know how to enable the shutdown command. But this is not what you are looking for. 😛
    If you want to fasten the Shutdown process, there is a Registry Hack.
  • PraveenKumar Purushothaman
    MemberJan 16, 2012
    If you need to shut down your Windows PC using command line, you can type: shutdown -s 😀
  • Abhishek Swain
    MemberJan 21, 2012
    This tip will help you. Do one thing. If your PC is running Windows Xp then good. Start the task manager, click on Shut Down drop-down menu. Press the shut down option while pressing the control key. See your PC shut down in 2-3 seconds. 😉
    MemberJan 21, 2012
    Abhishek Swain
    What difference does that make? Nothing here... Win XP SP3... 😀
  • Abhishek Swain
    MemberJan 22, 2012
    Praveen-Kumar
    Shocked !😲 Not working ? But it should work. But if your task manager loader is missing then am sorry friend. 😔
    MemberJan 22, 2012
    I am saying about this...
  • Abhishek Swain
    MemberJan 22, 2012
    Praveen-Kumar
    Pressing control key while clicking the shutdown option will cool shutdown your system without doing the following. So it takes very less time.
    • Save data in memory to virtual memory for future reference.
    • Flush the system memory.
    • Create logs.
    • Save configuration files. 😀
    MemberJan 22, 2012
    Abhishek Swain
    • Create logs.
    Yeah. I did, but I didn't find any difference... 😔 Will try again anyways... 😛
    MemberJan 22, 2012
    If you are saying this: #-Link-Snipped-#
    Then it works only in Windows 2000 Server!!! Please check and revert back... 😀
  • Rahul Jamgade
    MemberFeb 5, 2012
    Praveen-Kumar
    Well there are many ways to do it. It all depends on which OS you want to shutdown. Like Windows has its own way of remotely shutting down computer using command 'shutdown /m \\server /t 00' from a remote computer that has proper previleges. You can shutdown *NIX computers using 'ssh root@host' to login and executing 'init 0'. Also you get remote power switches from vendors like APC for remotely booting the power cycle of computer.
    MemberFeb 15, 2012
    ashhish000
    you can shut down windows by alt+f4, direct plugging off, by command line and in windows Xp
    press window button and then press 2 times "u"
    Dude, say some legitimate ones... Plugging off or Pouring water on motherboard and all won't work out!
    MemberFeb 15, 2012
    ashhish000
    Don't go on only "plugging off"...there are other ways are also given
    Still... 😛
  • sachin bankar
    MemberFeb 16, 2012
    Well....For Windows XP
    Just press window key once and then press "U" twice. your machine will be shut down.
    MemberFeb 16, 2012
    sachin bankar
    He he... Thats good as clicking start menu, clicking shut down, and clicking okay! 😛 You are just automating it with a keyboard and not a new method or something! 😲
