How to Rename Multiple Files in Once
Many of us have multiple files in hard drive. Most of them fed up to rename their multiple files. So here is the trick to rename multiple files in once.
In this trick the name will be same but all the files have continuous numbers with the file name.
STEPS :
* Select all the files you wish to rename. ( Use CTRL+A to select all the files or Hold CTRL key and select your files).
* After selecting the files press F2. (F2 is shortcut for rename).
* After that enter your file name and hit enter. Then you will see your selected all files will be renamed with continuous names.
