How to Post variables to url using function in php?
Manish Goyal
@manish-r2Hoep • Oct 22, 2024
I have a problem in php
basically if we want to pass post variable to a url using php we add
<form action="url">
</form>
But i want to pass it to url using function
for eg
function manish($_POST)
$url="https://example.com?";
$url.=$url.$_POST;
any idea how to do this?
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 Apr 12, 2011
    You cannot pass it using a function. But you can do so using headers...
    $host = "www.example.com";
    $path = "/path/to/script.php";
    $data = "data1=value1&data2=value2";
    $data = urlencode($data);
    header("POST $path HTTP/1.1\r\n");
    header("Host: $host\r\n");
    header("Content-type: application/x-www-form-urlencoded\r\n");
    header("Content-length: " . strlen($data) . "\r\n");
    header("Connection: close\r\n\r\n");
    header($data);
    @praveenkumar-66Ze92 Apr 13, 2011
    You can also use CURL to post the data and get the response back, either in a variable or in the output buffer... 😀
  • Prasad Ajinkya
    @prasad-aSUfhP Apr 15, 2011
    A simpler method would be to say method="GET" in your form tag. That way all the form inputs would be submitted as a GET and not as a POST.
    A more tedious approach to this would be to take the variables, encode them and then put that in the URL.
    @praveenkumar-66Ze92 Apr 15, 2011
    kidakakaA simpler method would be to say method="GET" in your form tag. That way all the form inputs would be submitted as a GET and not as a POST.
    Dude, both are simpler... What he is asking is, without a client side interaction, he wants to post the data to another URL got it??? Even I had a same problem but I used header post... 😀
  • Manish Goyal
    @manish-r2Hoep Apr 15, 2011
    Yes you are right ,but what i want to do is to pass variables to some url which user can' find to which page variables have been passed
    Anyway it has been done now with the use of curl
