How to open a applet, when opening the notepad file
ms_cs
@ms-cs-Ab8svl โ€ข Oct 25, 2024
I want to create an application that displays one applet window, when we attempt to open an notepad file. Is it possible ? How to do that ? [I want to do it in java]
  • shalini_goel14
    @shalini-goel14-ASmC2J • Jun 10, 2009
    Just check the event associted with 'opening a notepad file' (there are many ways for opening a notepad file -opening from code or manually from the system). If you know that then an applet window can be displayed based on it.
  • ms_cs
    ms_cs OP
    @ms-cs-Ab8svl • Jun 11, 2009
    Now I post my question clearly,
    while working in windows xp, one java file should always running in memory. That should monitor for the event, "opening notepad file, (any file)". When I am opening, ie when that event occurs it should display the applet.
  • ms_cs
    ms_cs OP
    How to do this?? Post your Ideas CEans
