how to measure weight of shaft mounted on lathe machine
akash_mech
@akash-mech-GgBhQ9 • Oct 22, 2024
hi
i m mech engg student ,,well i m doing project on productivity control in manufacturing industry. i got stuck at one place were i had to measure the wieght of shaft which is mounted on machine,.................pls suggest any mesuring instrument or technique expect the fomula (volume * density)
thanks
akash
  • xheavenlyx
    @xheavenlyx-CbvN62 • Jun 12, 2008
    Re: how to measure wieght of shaft munted on lathe machine
    Wow, this is an interesting problem.
    I can just think of one possible way if its difficult to measure density / volume. However i suspect the shaft SHOULD have its data sheet somewhere in the office (which gives all the important details like weight).
    Anyway, here is a try from my side, (correct anything if its wrong):
    I will be assuming the following data:
    1. your "Shaft" is a cylinder.
    2. Your shaft is connected to a motor which can rotate it.
    3. You have all the motor specifications like RPM, Power (kW) etc.
    We will use this formula to get the weight:
    For cylinder rotating along length..I (Moment of Inertia) is:
    [​IMG] So Mass(kg) = ( I[sub]z[/sub] * 2 ) / r[sup]2[/sup]
    How to find I (Moment of Inertia) ?:
    torque = I[sub]z[/sub] x Alpha (Angular Acceleration in rad/s)
    I[sub]z[/sub]= Torque in N.m / Angular Acceleration in rad/s[sup]2[/sup]
    How to find torque and Angular Acceleration?:
    Torque-N.m = (60,000 * Power in kWh) / ( 2 * pi * RPM motor rotation speed )
    Get power from Motor datasheet, or it will be printed on the motor in kW! Run the motor at constant speed to get RPM from a hand-held tachometer (Use same speed for other calculations).
    For Angular Acceleration:
    use this formula: final A.velocity in rad/s = Initial A.velocity in rad/s + Angular Acceleration * time in seconds.
    to use this, start the machine (Initial A.vel = 0) and calculate the time it takes to reach a constant final A.vel in RMP. Convert this final Angular Velocity to RPM by dividing the rad/s with 2pi. Then substitute in above formula to get Angular Acceleration in rad/s[sup]2[/sup].
    Do the above and (hopefully) you will get the shaft mass.
