how to measure the power output of an engine?
deepuhsr
@deepuhsr-9g4yIT โ€ข Oct 26, 2024
hi.. guys... i'm designing and fabricating a two stroke engine... will someone pl.. temme how to mesure the power output of my engine?.. i mean in terms of bhp ...
  • deepuhsr
    @deepuhsr-9g4yIT • Jan 23, 2011
    hello... pl..is der anyone to answer my question...?
    @thebigk • Jan 24, 2011
    deepuhsrhello... pl..is der anyone to answer my question...?
    It takes time for others to read and answer your question. Please refrain from using SMS text on CE Forums ๐Ÿ˜€
  • gohm
    @gohm-F3UUpP • Jan 24, 2011
    One common method is to use a dynometer. This will measure both hp and torque compared to rpm. Here is a lot of good introductory information on a dyno way better than I could type it out:
    <a href="https://en.wikipedia.org/wiki/Dynamometer" target="_blank" rel="nofollow noopener noreferrer">Dynamometer</a>
    If you need any other tips or assistance let us know!
  • deepuhsr
    @deepuhsr-9g4yIT • Jan 25, 2011
    ya i do know that gohm.. but i wanted to know in detail about whether the dia of my crank will match the dyno or not? or i need to do some arrangements like coupling to couple both?
  • gohm
    @gohm-F3UUpP • Jan 27, 2011
    That will totally depend on your motor and dyno used however most likely you will need a coupling device. Depending how percise, you can also use a belt or chain drive to transfer.
