@durga-TpX3gO • Feb 22, 2011
...get a genuine version :-\
@pensu-8tNeGU • Feb 22, 2011
Thats the problem when u use pirated version. There is no cure for that. Try reinstalling window or i guess there are some activators available, search on Google you will find one. After that please don't upgrade it....๐.
@kr-at-nsngu-XqzcfU • Feb 22, 2011
boharmy window is not genuine therefore it always show message to "make it genuine"..
how can i remove this message?
and i can't set wallpaper?u can't make it genuine ......
getting the genuine ver. is da 1nly possibility -
@slashfear-tSWzpz • Feb 22, 2011
Hi bohar,
Ok reinstalling the windows os is the option you have and once reinstalled make sure you turn of the automatic updates that should not allow the windows os to check for genuineness normally the third or the fourth update will be the genuine check so its better you turn off the automatic updates!! and if in case your using vista you have to use a keygen but I wont suggest you to go for it as it will for sure have backdoors in it (virus basically).
-Arvind -
@brajeshkumar-GiRicY • Feb 23, 2011
if u use crack version of window7 i think ur probleb is solve or u can try any version of window7 except window7 ultimate in other 7 thats is not problem
@praveenkumar-66Ze92 • Mar 2, 2011
We can make everything possible. You are using a pirated version of the operating system, which costs about 150 USD. Just think how much effort would those developers have put forth for making the successful OS. If you are trying out the cracks or patches, it would be possible. But, just think, when the developers can make an OS, why can't they find out that you are using a patched version and they can even sue you! Better advice, when you buy a new system, make sure, there is a genuine version installed and then pay. What say?
