How to make changes to aodv.cc in ns2 ?
eliza.m
@elizam-IEp56c โ€ข Oct 25, 2024
Hi crazy engineers ! I'm working on a code that implements frequency hopping using ns2..i need to add a part of code to the file aodv.cc..how do i make the changes effective ? kindly help me out...๐Ÿ˜€
  • sookie
    @sookie-T06sFW • Jul 19, 2012
    #-Link-Snipped-# Your problem is not cleared ๐Ÿ˜€
  • eliza.m
    @elizam-IEp56c • Jul 20, 2012
    Well...im using the network simulator 2 to check the throughput of frequency hopping...i need to add some code in the file named "aodv.cc" present in the ns2 folder. But after adding the code the change is not effective even after saving the changes. I think i have to use make command or make clean commands...but i am not sure how to go about it...if you are familiar with the tool ns2 pls help out...
