@koushal-C6mEgp • Mar 19, 2015
Awesome! 😀
#-Link-Snipped-# - Sir, do you have any way to slow down the melting of ice? I guess, the caging itself slows down the process, but any extra medium that we can combine with? Thanks in advance. -
@ramani-VR4O43 • Mar 19, 2015
If there is no air flow the thermocole box will slow down the ice melting. If the fan runs there is no escape from the mCp(delT) (airside) from melting an equivalent quantity of ice. Slowing the fan will slow it at the cost of reduced cooling.Koushal Patelany way to slow down the melting of ice? -
#-Link-Snipped-# - Sir I was asking about any material which can be mixed with ice to slow down its melting. Is it possible? -
The basic problem is that if any heat is added to ice it will melt consistent with its latent heat. In this case the fan is blowing outside warm air into the chamber. The higher temperature of the air melts the ice.Koushal Patel#-Link-Snipped-# - Sir I was asking about any material which can be mixed with ice to slow down its melting. Is it possible?
Unfortunately, any addition to the water will depress the melting point leading to faster melting.
This article will help to understand this:
Another:
<a href="https://www.ibchem.com/root_pdf/melting_point_depression.pdf" target="_blank" rel="nofollow noopener noreferrer">PDF</a> -
@abrakadabra • Mar 19, 2015
I have heard of salt OR pepper being added to salt to make it melt slower.Koushal Patel#-Link-Snipped-# - Sir I was asking about any material which can be mixed with ice to slow down its melting. Is it possible?
Not sure if it's true. Here's a link:
<a href="https://antoine.frostburg.edu/chem/senese/101/solutions/faq/why-salt-cools-icewater.shtml" target="_blank" rel="noopener noreferrer">General Chemistry Online: FAQ: Solutions: Why can adding salt to ice water make the ice melt slower?</a> -
@ramani-VR4O43 • Mar 20, 2015
Not really. What is said in the reference is the same mentioned in my post. Adding salt lowers the melting point, does not affect the amount melted.Ankita Katdareto make it melt slower. -
@sudharsansrinivas-2owsk3 • Apr 11, 2015
AS AKNITHA SAID IS CORRECT ADDING SALT TO ICE IT LOWER THE MELTING POINT I HAD DONE IT practically 😀 -
@ramani-VR4O43 • Apr 11, 2015
The total cooling capacity is still invariant. The latent heat does not change.sudharsansrinivasAS AKNITHA SAID IS CORRECT ADDING SALT TO ICE IT LOWER THE MELTING POINT I HAD DONE IT practically 😀
