  • How to make a controlling circuit for solar panel?
    Aakash R Mishra
    Aakash R Mishra
    @aakash-r-mishra-14VUkU
    Updated: Oct 26, 2024
    Views: 1.2K
    plz tell me basic circuit & kindly plz ellaborate....
    AdministratorAug 24, 2013
    Aakash R Mishra
    What do you want us to tell you about controlling circuit for solar panel? A more specific question would help us help you more effectively.
    Also, it'd be nice if you could make a few basic searches on Google and find out the circuit diagrams you are looking for.
  • Jeffrey Arulraj
    MemberAug 24, 2013
    Can you tell us the voltage range and the output of the solar panel and what is your load which you are planning to use ?
  • Aakash R Mishra
    MemberAug 26, 2013
    i had tried alot many times bt i coudn't find out..... & many times it provided me with only companies product but not about it circuit daigram or its working.
    it solar panel is rated for 12 volt dc. & 3watt.
  • Aakash R Mishra
    MemberAug 26, 2013
    the solar panel is rated for 12 volt dc. & 3watt.
  • Aakash R Mishra
    MemberAug 26, 2013
    i simply want atleast how could i control the solar power from the sun. i simply want its basic ckt. & working too....
  • KenJackson
    MemberAug 27, 2013
    Typically you charge a lead-acid battery by day and use the battery power by night.
    You'll need a solar panel with an open-circuit voltage that's larger than your battery and some kind of solid state switch in series with the panel that cycles open and shut as needed to maintain the right voltage to charge the battery. You need to put some thought into the algorithm that cycles the switch.
    Fortunately, solar panels don't suffer if you suddenly open-circuit them (you wouldn't want to do that with a rotating generator).
    If you have nine 1.2 V AA rechargeable cells in series as load across the output, you may not need any circuit at all.
  • narayana murthy
    MemberAug 31, 2013
    if the voltage is 12v and 5a you can use ULN2012 ic if it 6v u can use ULN2006 ic but 1 thing these are voltage regulators as output of solar is not continous in my project i have used ULN2012 i think.
    Coming to batteries you can have recharge batteries at 12v and 6v more than this you can use voltage regulators and an invertor circuit for the functionalities
  • kumarrakeshit
    MemberMay 1, 2016
    Hi Gus,
    Can I direct run fan(220 volt) using solar panel without using battery?
  • KenJackson
    MemberMay 5, 2016
    kumarrakeshit
    A 220V fan most likely requires AC voltage, whereas solar panels produce DC voltage. You would need an inverter, that is, a device that generates a near sine wave output (AC) from a DC input.
  • kumarrakeshit
    MemberMay 20, 2016
    Let me know if I am using inverter that convert dc to ac, after inverter can I use step up transformer to produce height voltage.
    so that I can run multiple electronic device.
    kumarrakeshit
    An inverter can directly produce 220V 50Hz supply.
