How to make a basic steering system
senoj90
@senoj90-s3rv5J Oct 27, 2024
Hi,..
I am in 2nd yr mechanical engineer. I am trying to make a steering system. I dont understand how the part that connects the wheel remains stationary and deviates it, without it being rotated along the wheel..
Any object connected with the wheel should also rotate along with it right? Please help me on how the wheel is moved by the rod? any help is appreciable....
  • gohm
    @gohm-F3UUpP Mar 20, 2010
    Are you referring to the steering wheel or wheel with tires? I think you are interested in the hub which allows a rotational mass to travel on a fixed point.
  • senoj90
    @senoj90-s3rv5J Mar 20, 2010
    I wanted to know, how the rotational input from steering wheel is transferred to the tires. Something has to push the tires while it is rotating in order to turn it right? My question is how does the rod that pushes the tires, remains stationary(without rotating) even though the tires which is connected with the rod rotates. What mechanism or what device keeps the tires rotating while to rod that pushes the tires remains stationary?
  • vikas.v
    @vikasv-L9OmkH Apr 10, 2010
    i am working on sae baja i need to know which mechanism of steering is feasible for all terrain vehicle
  • sumitkujha
    @sumitkujha-VvTIPQ Apr 20, 2010
    hey its all depend on the hub,axle,& the shaft.................
  • sumitkujha
    do u ever make its promo type........
  • vikas.v
    @vikasv-L9OmkH Apr 23, 2010
    Re i need to know whether we can use power steering in all terrain vehicle
    hey i need to know whether we can use power steering in sae baja vehicle
  • gohm
    @gohm-F3UUpP Apr 24, 2010
    Yes you can use power steering. However many times in recreational or racing applications manual steering forms are preferred to maximize power to the wheels and decrease weight.
  • nick_cardoza
    @nick-cardoza-hfOsHa May 3, 2010
    what class vehicle are you building for baja? and you may want to look into manual steering with a steering quicken-er. ran one on my old score race truck and it was an amazing investment. ill look now to see if i have pictures from the front to show you a diagram of the steering linkages.
