  • How to learn electronic circuits?
    gmasarath
    Member
    Updated: Oct 26, 2024
    Views: 1.2K
    😕i am b.e student and i want the procedure to learn about the electrical circuits 1pls tell me the shortcuts to learn ec-1:?::?:😕😕😕😕😕😕 pls help me
  • gargoor
    MemberNov 17, 2010
    you should understand the basics 1st as in :
    what is voltage
    current
    resistor
    inductor
    capacitor
    diode
    trasistor
    frequency
    power
    .. etc
    measuring tools :
    oscilloscope
    multimeter
    then the relation between each of them
    get an introduction to electrical and electronic book for students it'll be easy by following the chapters and solving the questions but every question you face it's better to apply it in practicle for a solid understanding. If you don't have practicle skills, it'll be challenging in the beggining so you should try to learn how to use the soldering tools, and know what is PCB , or else you can use a breadboard that doesn't require you to solder at all
    take your time in understadning and know the applications for each thing so u get more excited and can connect what you learn in reality
    don't worry if you wont understand everything now , eventually you will
    else you can start by simple projects , check the vids around
    best wishes​
  • nsiva007
    MemberNov 25, 2010
    There are no short cuts to learning.. if you follow shortcuts it will lead to a kinda cramped learning pyramid... Just understand your basics and put some effort..! What lessons are you learning in EC-1????
  • poonam biswakarm
    MemberNov 25, 2010
    hiieee ..
    There is no royal road to electronic circuits.. don't go for shortcuts. make your base clear first even the toughest circuit will be simple for you. Good luck.
  • narayana murthy
    MemberNov 29, 2010
    i know only one short cut way try to know logics in it so finally unknowing u can learn all in electrical subjects as iam from jntu i dont know much about b.e subjects
