How to hack the firefox for fast performance?
Reya
Reya
@reya-SMihdC Oct 26, 2024
Hi friends got an informative latest news for you all!There are many people out there complaining about the Firefox RAM Memory Bug. Its not a bug. It’s part of the cache feature. This is how the web pages are cached in a tabbed environment.
To improve performance when navigating (studies show that 39% of all page navigations are renavigations to less than 10 pages which were already visited usually using the back button)Here Firefox implements a Back-Forward cache that retains the rendered document for the last five session history entries for each tab.
If you have a lot of tabs, Firefox’s RAM memory usage can climb in an impressive manner. What you get out of it is faster performance as you navigate the web.
Now a lot of us have found the secrets on how to manipulate settings in about:config to drop the memory usage as long as possible and to increase the speed at which Firefox loads sites.
These tweaks below will make it even greater and faster. So enjoy!
Reduce the amount of RAM Firefox uses for its cache feature:
Here are the steps how to do it:
1. Type about:config in the adress bar in the browser.
2. Find browser.sessionhistory.max_total_viewer
3. Set its value to zero
Increase the Speed in Which Firefox loads pages
1. Type about:config into the address bar and hit Enter.
(Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.)
2. Now Alter the entries as follows:
Set network.http.pipelining to true
Set network.http.proxy.pipelining to true
Set network.http.pipelining.maxrequests to some number like ten.
This means it will make ten requests at once.
3. Finally right-click anywhere and select New-> Integer. Name it nglayout.initialpaint.delay and set its value to Zero
This value is the amount of time the browser waits before it acts on information it receives. If you’re using a broadband connection you’ll load pages faster now.
Optionally (for even faster web browsing) here are some more options for your about:config (you might have to create some of these entries by Right Click –> New– > Interger or String
network.dns.disableIPv6: set false
content.notify.backoffcount set Five
plugin.expose_full_path set true.
ui.submenuDelay set zero
Reduce RAM usage to 10mb when Firefox is minimized:
This little hack will drop Firefox’s RAM usage down to 10 Mb when minimized:
1. Open Firefox and go to the Address Bar. Type in about:config and then press Enter.
2. Right Click in the page and select New -> Boolean.
3. In the box that pops up enter config.trim_on_Minimize Press Enter.
4. Now select True and then press Enter.
5. Restart Firefox.
These simple tweaks will make your web browsing with Mozilla Firefox 2-3 times faster and easier. And I think they are fairly easy to apply. Enjoy!
  • gizmotech
    gizmotech
    @gizmotech-jrU4t8 Dec 12, 2010
    Hello,
    It would be nice if we have a protocol by which we mention the source of all such posts.
    Thanks for the information
  • Deepika Bansal
    Deepika Bansal
    @deepika-jf1ysv Dec 13, 2010
    Nice information....Thanks Parveena.
