plese friends gvie me some ideas regording to ,how to found the brack off railway tarcks.............0
Member • May 20, 2011
Could you please give us more information? Are you trying to make a device that will measure when a railroad track is about to break? Anything more you tell us will allow us to better help you.Are you sure? This action cannot be undone. -
yes sir,am asking about how to found the broking poing of railway tracks.........can you know any one techinqueAre you sure? This action cannot be undone. -
i have one idea.........so that am askingAre you sure? This action cannot be undone. -
You could use a force transducer connected to a computer or micro controller. You could place the force sensor beneath the piece of railway track then apply force to it til it breaks and measure it at that point.Are you sure? This action cannot be undone. -
i have one ide!that is, we are manufacture the railway track with small power transmission electrical wire ......it is along witth in the track ,we can put a signal lights at every 5km distance...when the train driver identifies it then take care............i think its very use full and better.......any one plese give me some suggitions.........Are you sure? This action cannot be undone. -
Member • May 24, 2011
Sorry I thought you meant how much force it would take to break a railway track, my mistake.
There are devices that are available to measure the distance to an open in a wire. You can read about them here: <a href="https://en.wikipedia.org/wiki/Time-domain_reflectometer" target="_blank" rel="nofollow noopener noreferrer">Time Domain Reflectometer</a>
So like you said you could have a wire going along with the railway track and measure if there is an open circuit anywhere along the track. I'm not sure how much distance these devices can measure so you will have to do a little more research.Are you sure? This action cannot be undone. -
yes ,your correct but that wire is along with the track......every 5km we will put a signal point ............Are you sure? This action cannot be undone. -
Member • May 27, 2011
Railway track is already a conductor. All you got to do is send some spike voltages periodically and check the continuity of the track.
But this may not be an efficient one.
venueeeyes ,your correct but that wire is along with the track......every 5km we will put a signal point ............Are you sure? This action cannot be undone. -
Member • May 31, 2011
5km is a very long distance to try and find an open along a wire. How would you setup the wire? If the wire is in series, and the line breaks, all the lights will go out. You would have to set them up in parallel.Are you sure? This action cannot be undone. -
Member • Jun 19, 2011
yes,but hear continuce power supply is giving to the wire so ,if any break occured then immediatly ,we can get the signalAre you sure? This action cannot be undone.
