@thebigk • Feb 5, 2009
Re: How to exicute an applet program written in java
rama_krish627Hi friends. Can any one tell me how to execute an applet program.
You'll have to embed it in HTML. Do you know how to do that?
@shalini-goel14-ASmC2J • Feb 5, 2009
Hi rama_krisha
Applets can be executed in 2 ways:
1. Executing the applet within a java-compatible web browser.
For this write html code that has APPLET tag.
<applet code="[your java file name]" width=200 height=200> </applet>
Now simply run this file as a normal html file.
2. Using an applet viewer. Applet viewer executes your applet in a window. This is fastest and easiest way to test your applet.
In this make a separate file AppletHtml.html of same code as above.
Then run above file as following command:
C:\>appletviewer AppletHtml.html
3. Better is one more way which is more commonly use - Simply include a comment at the head of you Java file/program
/* <applet code="[your java file name]" width=200 height=200> </applet> */
Then execute the appletviewer as told in point no2.
Hope I am correct and can be helpful .Others can correct me. ๐ -
@rama-krish627-LuiiO6 • Feb 6, 2009
ya it's working. but the last one is not working. -
@shalini-goel14-ASmC2J • Feb 6, 2009
rama_krish627ya it's working. but the last one is not working.
Hi rama_krish,
What is not working? What steps you followed to do so. Better share your program here if you have no issues with it. ๐ -
@sookie-T06sFW • Aug 21, 2009
Hi rama_krish627,
To make the last case working, you need to follow following three steps
Step # 1: Edit your Java source file.Add following lines of code in your java class file
Step # 2: Compile your program
Step # 3: Execute the appletviewer , specifying the name of your applet's source file. For eg., if your applet's source file(or your java program only) is in folder I:\JavaSrcCode then open command prompt ->switch to the location of your java(or applet ) source file-> type following command at it
I:\JavaSrcCode>appletviewer MyFirstApplet.java
