How to estimae total number of brick required
santosh.aherkar
@santoshaherkar-Yg0iaF โ€ข Oct 26, 2024
If I want to built a wall of say 10' X 10'. Considering the brick dimensions as 9"X4"X2.5" & wall width 1' (correct me if i am wrong in case of dimensions) , how many bricks will i require? You can change dimensions as per your convenience. FYI, I have to built a new house so to estimate the total bricks i need this calculation. If needed u can contact me on #-Link-Snipped-#
  • Prasad Ajinkya
    @prasad-aSUfhP • Jan 27, 2008
    Santosh, this is based on simple mensuration.
    First you need to find the total surface area of the house, then you need to determine how thick a wall you will need. That gives you the total brick volume.
    Then just divide that by the individual volume of a brick. Ensure that both the quantities are of the same unit (Cubic CM is advised).
    Round off to the nearest round figure to accommodate wastage and breakage.
  • engr.khawar
    @engrkhawar-BtrBO6 • Feb 16, 2008
    hi my friend.first your dimensions for brick is worng.it is 9"x4.5"x3".now first u find the volume of brick.it is .0703 cu ft.now find the volume of your wall which is 10'x10'x1'=100 cu ft.the no of your bricks are 100/.0703=1423 bricks.so it is the no of bricks for 1 wall of dimensions of 10'x10'x1'.hope it will be answer.
  • VINAYAK PADMANE
    @vinayak-padmane-osEro5 • Apr 7, 2023
    Is there any standard set for brick calculation?(like for 1cum = 500 nos please reply me asap.)
