How to disable the value of Combobox in javascript ?
RajanV
@rajanv-sfnA6E โ€ข Oct 27, 2024
Hi I need some help. I have three comboboxes :
Each combobox have following values to select :
Combobox 1:
English
French
Spanish
Italian
Combobox 2:
English
French
Spanish
Italian
Combobox 3:
English
French
Spanish
Italian
When the values are selected in Combobox 1 let's say English, then this value is to be disabled in Combobox 2 & 3 both. I want to do this in javascript. can any body help.
Thanks in advance
  • simplycoder
    @simplycoder-NsBEdD Sep 22, 2014
    Show us what have you tired.
    Also please clarify if you want it to disable the value or remove it from combo box.
  • Prasad Ajinkya
    @prasad-aSUfhP Sep 24, 2014
    Prepopulate the language strings in an array
    On change of the first dropdown/selelct, empty the 2nd and 3rd dropdown and populate them with all strings except the one in the 1st.
  • RajanV
    @rajanv-sfnA6E Sep 24, 2014
    Sorry for the late reply. I tried this code. Could any one help me out of this now. Because i not getting how would i get into this ...
    <html>
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
      <script type="text/javascript">
      function selectedLanguage(lang,comboxbox_id){
      console.log(comboxbox_id);
      var langSelected = lang.options[lang.selectedIndex].value;
      console.log(langSelected);
      if(comboxbox_id === 'language1'){
      if(langSelected === 1){
      //do nothing
      document.getElementById('language2').style.disabled = true;
      }else if(langSelected === 2){
      }else if(comboxbox_id === 'language2'){
      //do nothing
      </script>
      </head>
      <body>
      <select name="language1" id="language1" onchange="selectedLanguage(this,this.id)">
      <option value="1">Disabled</option>
      <option value="2">English US</option>
      <option value="3">Greek</option>
      <option value="4">Swedish</option>
      </select>
      <select name="language2" id="language2" onchange="selectedLanguage(this,this.id)">
      </select>
      </body>
    </html>
  • Manashree Thokal
    @manashree-7mZH3V Sep 26, 2014
    Did you check if there are any js errors on the browser?
    Debug using F12 button on browser.
    @anoop-kumar-GDGRCn Sep 26, 2014
    Try this.. #-Link-Snipped-#
    I got little time and did this. but it's not full.
    You can disable the drop down after selecting it and if user want to select again. add a reset button to reset all the drop-down. I think it should be fine after that.
