@rahul69-97fAOs • Jan 27, 2013
Hi there! I think u need to use JDBC for your purpose. Make a patient reading about it. For start, check out this link : <a href="https://docs.oracle.com/cd/B19306_01/java.102/b14355/overvw.htm#CJAHEFFI" target="_blank" rel="nofollow noopener noreferrer">Introducing JDBC</a>
@anoop-kumar-GDGRCn • Jan 27, 2013
import java.sql.DriverManager; import java.sql.Connection; import java.sql.SQLException; public class OracleJDBC { public static void main(String[] args) { Connection conn= null; try { Class.forName("oracle.jdbc.driver.OracleDriver"); conn= DriverManager.getConnection("jdbc:0racle:thin@localhost:1521:DB_NAME", "username", "password"); }catch (SQLException e) { e.printStackTrace(); } }You might know above code. but first check your DB is up and running by openind SQLPlus from start menu and connecting by admin and password you given at installation time.
If this program is ok then just use this connection (conn) object to insert into table and then fetch them.
If you have some problem post here.
@krishbcs-5tG26c • Jan 29, 2013
ianoop
ianoop
try
conn= DriverManager.getConnection("jdbc:0racle:thin@localhost:1521:fea", "scott", "tiger");
while compile above program, following error occurs...................
--------------------Configuration: <Default>--------------------
C:\Documents and Settings\user\Desktop\Project\new\OracleJDBC.java:14: unreported exception java.lang.ClassNotFoundException; must be caught or declared to be thrown
1 error
Process completed. -
And also try this, BUt it also error:
import java.sql.ResultSet;
import java.util.Properties;
import java.sql.PreparedStatement;
* Simple Java Program to connect Oracle database by using Oracle JDBC thin driver
* Make sure you have Oracle JDBC thin driver in your classpath before running this program
* @author
public class OracleJdbcExample {
public static void main(String args[]) throws SQLException {
//URL of Oracle database server
String url = "jdbc:0racle:thin@localhost:1521:fea";
//properties for creating connection to Oracle database
Properties props = new Properties();
props.setProperty("user","scott");
props.setProperty("password","tiger");
//creating connection to Oracle database using JDBC
Connection conn = DriverManager.getConnection(url,props);
String sql ="select sysdate as current_day from dual";
//creating PreparedStatement object to execute query
PreparedStatement preStatement = conn.prepareStatement(sql);
ResultSet result = preStatement.executeQuery();
while(result.next()){
System.out.println("Current Date from Oracle : " +result.getString("current_day"));
System.out.println("done");
Compile Error is NO
but Run time Error occur
Exception in thread "main" java.sql.SQLException: No suitable driver found for jdbc:0racle:thin@localhost:1521:fea
at java.sql.DriverManager.getConnection(DriverManager.java:640)
at java.sql.DriverManager.getConnection(DriverManager.java:169)
at OracleJdbcExample.main(OracleJdbcExample.java:26)
@anoop-kumar-GDGRCn • Jan 29, 2013
Do you have classes12.jar in your class path. download it and paste it into jdk lib.
It should solve your problem.
Tip: For any oracle/java error/exception just search google by that whole error and find answer on coderanch.com or #-Link-Snipped-#😀
you can find 99.99 answers on these sites. -
@krishbcs-5tG26c • Jan 30, 2013
hai, i almost complete my connection, but i can not clear this error please tell solution for following error:
Exception in thread "main" java.sql.SQLException: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
at sun.jdbc.odbc.JdbcOdbc.createSQLException(JdbcOdbc.java:6956)
at sun.jdbc.odbc.JdbcOdbc.standardError(JdbcOdbc.java:7113)
at sun.jdbc.odbc.JdbcOdbc.SQLDriverConnect(JdbcOdbc.java:3072)
at sun.jdbc.odbc.JdbcOdbcConnection.initialize(JdbcOdbcConnection.java:322)
at sun.jdbc.odbc.JdbcOdbcDriver.connect(JdbcOdbcDriver.java:173)
at java.sql.DriverManager.getConnection(DriverManager.java:620)
at java.sql.DriverManager.getConnection(DriverManager.java:200)
at jack.Database.<init>(Database.java:20)
at addItem.<init>(addItem.java:21)
at addItem.main(addItem.java:90)
@anoop-kumar-GDGRCn • Jan 30, 2013
This seems , you are connecting to Microsoft access DB not the oracle db . right?
then check this out.
#-Link-Snipped-# -
@krishbcs-5tG26c • Jan 31, 2013
yes this exception error cleared. but another one exception is following please try for me.
this is my Database Connection program....(Database.java)
package jack;
import java.util.logging.Level;
import java.util.logging.Logger;
import java.sql.Statement;
public class Database
Connection cn;
ResultSet rs;
Statement stmt,stmt1;
public Database()throws Exception
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver");
cn=DriverManager.getConnection("jdbc😲dbc:fea","system","mypassword");
cn.setAutoCommit(true);
stmt=cn.createStatement();
stmt1=cn.createStatement();
public ResultSet Select(String qry)throws Exception
rs=stmt.executeQuery(qry);
return rs;
this is my addItem Program😔addItem.java)(Form Design) this has two text field one is ited Id and another one Item name. One save button, while i click save, i need to insert data to my database.
import java.awt.Frame;
import java.awt.Button;
import java.awt.Label;
import java.awt.TextField;
import java.awt.event.ActionListener;
import java.awt.event.ActionEvent;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowListener;
import java.awt.event.WindowEvent;
import jack.Database;
import jack.Same;
public class addItem extends Frame implements ActionListener
Button save_item,clear_item,cancel_item;
Label lid_item,lname_item;
TextField tid_item,tname_item;
ResultSet rs;
Database db=new Database();
String Qry,dat;
public addItem()throws Exception
setTitle("Add Item");
setLayout(null);
lid_item=new Label("Item Id");
add(lid_item);
lid_item.setBounds(70,50,40,20);
lname_item=new Label("Item Name");
add(lname_item);
lname_item.setBounds(70,100,65,20);
tid_item=new TextField(20);
add(tid_item);
tid_item.setBounds(200,50,120,20);
tname_item=new TextField(20);
add(tname_item);
tname_item.setBounds(200,100,120,20);
save_item=new Button("Save");
add(save_item);
save_item.setBounds(100,150,50,20);
clear_item=new Button("Clear");
add(clear_item);
clear_item.setBounds(200,150,50,20);
save_item.addActionListener(this);
addWindowListener(new WindowAdapter() {
public void windowClosing(WindowEvent we)
{ dispose(); }
setSize(400,200);
setVisible(true);
setLocation(400,200);
public void actionPerformed(ActionEvent ae)
int no=Integer.parseInt(tid_item.getText());
String name=tname_item.getText();
Same s=new Same();
s.summa(no,name); // this is method from Same.java
dispose();
public static void main(String args[])throws Exception
new addItem();
and also i use following to support this process😔Same.java)
package jack;
public class Same
ResultSet rs;
Database db;
String Qry,dat;
public void summa(int no,String name)
try
db=new Database();
Qry="insert into rawmaterial values("+no+",'"+name+"')";
System.out.println(Qry);
rs=db.Select(Qry);
rs.next();
dat=rs.getString(1);
catch(Exception e)
first i compiled Database.java program: process completed.
second i compiled Same.java program: process completed.
third i compiled addItem.java program: process completed.
while i run third program the following error come:
Exception in thread "main" java.sql.SQLException: [Microsoft][ODBC driver for Oracle][Oracle]ORA-12154: TNS:could not resolve the connect identifier specified
at addItem.<init>(addItem.java:22)
at addItem.main(addItem.java:79)
Process completed.
what did mistake here. -
@anoop-kumar-GDGRCn • Jan 31, 2013
This driver is not used to connect oracle driver.
Which database you are using. if oracle then first try to connect using SqlPlus from program menu. then use code from my first post. or you can find oracle driver code on google easily. -
boss... I have installed Oracle 10g and java jdk1.7.0.
you mean Oracle jdbc driver?
After download this what i do? -
ianoopThis driver is not used to connect oracle driver.
Which database you are using. if oracle then first try to connect using SqlPlus from program menu. then use code from my first post. or you can find oracle driver code on google easily.using sql plus i created table only. Using sql plus how to connect with java?
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver"); The above line used to connect bridge between jdbc and odbc which is used for Microsoft access. Class.forName("oracle.jdbc.OracleDriver") used to connect Oracle database.have patience to read following
<a href="https://docs.oracle.com/cd/E11882_01/appdev.112/e13995/oracle/jdbc/OracleDriver.html" target="_blank" rel="nofollow noopener noreferrer">OracleDriver (Oracle ® Database JDBC API Reference)</a>
Here is full example:#-Link-Snipped-# -
@krishbcs-5tG26c • Feb 5, 2013
thanks boss i have connected successfully and also can inserted record.
