  • Pensu
    @pensu-8tNeGU • Dec 24, 2011
    Try Adobe Reader X, it can convert files into pdf online. If you want simple solution then use Microsoft Office, its doesnt have anything specific for HTML files. But you can copy the content of your files there and save that file as pdf.
  • Reya
    @reya-SMihdC • Dec 24, 2011
    Copying consumes lot of time.I wanted to combine all the Html files and convert into a single pdf file. you got me?
  • Pensu
    Hmm....looks like you can do this using Adobe Acrobat. Check this:
    I found one more software:
    Just one twist, none of them are freeware......๐Ÿ˜‰. You can trick simpo by telling it to remind you to register later, but the converted pdf will have "simpo" name on it...๐Ÿ˜›
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Dec 25, 2011
    You can do this. In Adobe Acrobat, you can Create PDF from Multiple Files. Try it out. ๐Ÿ˜€
    Step 1:
    [โ€‹IMG]
    Step 2:
    [โ€‹IMG]
    Step 3:
    [โ€‹IMG]
    Step 4:
    [โ€‹IMG]
  • Gandalf
    @gandalf-RPhbu3 • Dec 25, 2011
    Its a pro version adobe acrobat !!!
    Find appropriate link to download it
    You could use virtual printer like PDF lite
    GandalfIts a pro version adobe acrobat !!!
    Yeah, you can get one on the internet... Trial is free for personal use and, yeah, should I say that we CANNOT get it otherwise?
  • AllenJones
    @allenjones-ZNADS4 • Dec 27, 2011
    HTML pages conversion may cause several difficulties for those who need nonstandard page-per-file converting to PDF. As a rule most of HTML converters provide converting each source page to a separate file of appropriate format. But if you have dozens of parent pages that have to be converted, it is more reasonable to convert all HTML pages into one PDF file. In such a way all information from HTML pages will be combined into one PDF file. Total HTML Converter is able to combine HTML into one PDF file, as well as convert each HTML page separately. If you need the first variant, means โ€œall-in-oneโ€ conversion, you may perform several simple actions in the program. First you need is to select all HTML pages for conversion in the navigation section of the program. When Total HTML Converter is launched you may see the list of computer folders to the left and the list of files from the selected folder in the center part of the window.
    Thanks a lot.
    Allen Jones
  • Reya
    @reya-SMihdC • Dec 27, 2011
    In simpopdf,i couldnt find the HTML files when i click browse option. I tried Adobe acrobat professional and converted into pdf. Thank you guys for your replies ๐Ÿ˜€
    I havent tried total HTML converter. Will try it and let you know!
  • candysmith
    @candysmith-TFCBBL • Apr 28, 2014
    PensuHmm....looks like you can do this using Adobe Acrobat. Check this:
    #-Link-Snipped-#<a href="https://www.rasteredge.com/how-to/vb-net-imaging/pdf-merge-split/" target="_blank" rel="nofollow noopener noreferrer">VB.NET PDF: Use VB.NET Code to Merge and Split PDF Documents</a>
    I fail to trick simpo๐Ÿ˜ญ, and it asked me to register first.๐Ÿ˜”
