CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@Radhika Deshpande • 01 Jan, 2017 • 1 like
Problem : How To Check CheckBox From Multiple CheckBoxes On WebPage Using Data Driven FrameWork(Excel) In Selenium WebDriver with JAVA.
Scenario : I am currently automating a form where I am passing all input from excel. It includes textboxes ,checkboxes datepicker etc.
Form includes total 15 checkboxes. Now I want my script to check 1 checkbox which is mentioned in excel. I am using TestNG and Apache POI for it.
Here is what I have done to get it :
Here // String EventCategory is the Checkbox option I am passing as parameter from excel.
Could you please help in this what is wrong here? I am not able to check any checkbox with this.
HTML Tag:
public void EventCreation1(String EventName, String EventTagLine,String EventOrganization,String City,String State,String Country, String EventCategory ,String EventDescription,String Name,String EmailID,String Contact) { driver.get("WEBPAGE URL"); driver.findElement(By.xpath(".//*[@id='eventName']")).sendKeys(EventName); driver.findElement(By.xpath(".//*[@id='eventTagLine']")).sendKeys(EventTagLine); driver.findElement(By.xpath(".//*[@id='organizerName']")).sendKeys(EventOrganization); driver.findElement(By.xpath(".//*[@id='eventCity']")).sendKeys(City); driver.findElement(By.xpath(".//*[@id='eventState']")).sendKeys(State); driver.findElement(By.xpath(".//*[@id='eventCountry']")).sendKeys(Country); //For Category List<WebElement> Checkbox = driver.findElements(By.xpath("//input[@type='checkbox']")); for(int i=0; i<Checkbox.size();i++ ) { WebElement El =Checkbox.get(i); String id =El.getAttribute("value"); if(id.equals(EventCategory)) { El.click(); } }
HTML Tag:
<div class="section colm colm9"> <div class="frm-row"> <div class="section colm colm4"> <div class="option-group"> <label class="option option-blue block"> <input type="checkbox" name="eventType[]" value="TechFest"> <span class="checkbox"></span> TechFest </label> <label class="option option-blue block spacer-t10"> <input type="checkbox" name="eventType[]" value="Cultural Fest"> <span class="checkbox"></span> Cultural Fest </label> <label class="option option-blue block spacer-t10"> <input type="checkbox" name="eventType[]" value="Management Fest"> <span class="checkbox"></span> Management Fest </label> <label class="option option-blue block spacer-t10"> <input type="checkbox" name="eventType[]" value="Sports Fest"> <span class="checkbox"></span> Sports Fest </label> <label class="option option-blue block spacer-t10"> <input type="checkbox" name="eventType[]" value="Workshop"> <span class="checkbox"></span> Workshop </label> </div><!-- end .option-group section --> </div> </div> </div>
@Ankita Katdare • 02 Jan, 2017
Tagging @Saandeep Sreerambatla @Anil Jain Please tag anyone who may be familiar with the issue.
@simplycoder • 05 Jan, 2017 • 1 like
I do not have selenium set up with Java here, but just to clarify,
- Are you getting the correct number of check boxes in the list List<WebElement> Checkbox
- The case of String id =El.getAttribute("value"); is same as the one passed in EventCategory.
@Radhika Deshpande • 06 Jan, 2017
@simplycoder Thnaks for looking into it.
I am getting correct number of checkboxes in List .i.e 15 .
But problem is in Web element El I am getting all checkboxes values and then with
if(id.equals(EventCategory) it compares all values with one value in 'EventCategory' and fails.
Do I need iterate a list of WebElements and then compare it with EventCategory and then perform action of Click() ?
@simplycoder • 07 Jan, 2017
I would try this if I were you
The code above needs to be optimized ( Calling .get(i) twice...).
If not let me know.
I think you are correct in a way.Radhika@simplycoder Thnaks for looking into it.
- Get the list of check boxes (You already done that)
- Iterate through the list of check boxes with value attribute
- try something like this
String id = Checkbox.get(i).getAttribute("value"); if(id.equals(EventCategory)) { Checkbox.get(i).click(); // break if its only going to be one value. }Does this give you the correct output?
If not let me know.
@Saandeep Sreerambatla • 10 Jan, 2017 • 1 like
I think what gave above is correct, can you also perform trim as well. ( I think you might have done it already though)..
@Radhika Deshpande • 10 Jan, 2017
@simplycoder I tried this piece of code but it is not working. Do I need to use Iterator() method or ListIterator() method in java to iterate through the list of check boxes with value attribute?simplycoderString id = Checkbox.get(i).getAttribute("value"); if(id.equals(EventCategory)) { Checkbox.get(i).click(); // break if its only going to be one value. }
Thanks @Saandeep Sreerambatla for looking into it. I have not used trim() function as of now. I am JAVA beginner, thus not sure of what all function should be suitable for which condition. I will try in my code and let you know.Saandeep SreerambatlaI think what gave above is correct, can you also perform trim as well. ( I think you might have done it already though)..
@Radhika Deshpande • 11 Jan, 2017 • 2 likes
Hello ,
I tried below piece and it worked :
List<WebElement> Checkbox = driver.findElements(By.xpath("//input[@type='checkbox']")); int i=0; while(i<Checkbox.size()) { WebElement El =Checkbox.get(i); String id =El.getAttribute("value"); driver.manage().timeouts().implicitlyWait(5000, TimeUnit.SECONDS); if(id.equals(EventCategory)) { Checkbox.get(i).click(); break; } i++; }//End While
@Saandeep Sreerambatla • 12 Jan, 2017 • 1 like
So the wait statement did the trick!
So always use it whenever something doesnt work, it helps. And Instead of using something like as implicit wait create something for explicit wait , I mean a user defined wait function to wait for appropriate times.
@Radhika Deshpande • 12 Jan, 2017
Thanks a lot, i will make a note of it onwards 😀Saandeep SreerambatlaSo the wait statement did the trick!
@simplycoder • 14 Jan, 2017 • 1 like
Ideally it would wait till the element is loaded.
In this way you can maintain log of loading times of all controls on UI.
But this doesn't seem to be with the context of the question asked.
Issue with this code, is the hard-coded 5000 seconds.Saandeep SreerambatlaSo the wait statement did the trick!
@Amar Khavashi • 17 Sep, 2018 • 1 like
Hi radhika, nice tutorial.. I m facing issues in selecting values from excel file to select drop down values , please can you show me complete detail example
@Radhika Deshpande • 01 Oct, 2018
Hi Amar, Where exactly the problem you are facing? I am happy to help if you put your sample code.
7.1k views
@Debasmita Banerjee · Mar 1, 2017
A couple of weeks back, I saw my 8-year-old cousin heavily concentrating on a hole near the gateway to the kitchen and counting something invisible to my eyes. I approached...
3.2k views
@Radhika Deshpande · Jul 11, 2016
Born and brought up in Mumbai, Lakshmi Ananthamurthy is a Construction Engineer by degree and an MBA graduate from The University of Chicago Booth School of Business. A mother of...
5.5k views
@prakash.athani · Oct 16, 2008
0x80000000 (-2147483648) represents minimum value for signed integers for 32-bit machines.
4.1k views
@sad_engineer · Jan 18, 2013
Hello to all!!! I am a student of computer system engineering...I have to make project on
Computer Communication and Networking and also on Digital Image Processing...
as i am a...
9.5k views
@ROBOMOORTHY · Sep 20, 2012
can u say any body what is the advantage of knuckle joint over other joint?
8.7k views
