How to add to current sources
yogi.bharadwaj
@yogibharadwaj-l2QJTU โ€ข Oct 26, 2024
How to add two current sources to get output as the sum of both.for eg. If i have two current sources 4amp & 6amp then how can i connect to get 10amp as output?
  • mifo
    @mifo-JESyka • Sep 23, 2013
    If you are talking about the connection then the current sources should be connected in parallel to the load.
    @ramani-VR4O43 • Sep 23, 2013
    Better have a forward biased diode at the output of each source. It would be even better to have some current limiting protection on each for exigencies. This would cover mismatches in voltage and prevent shorting out of either source.
