How to add spaces in between characters in a char array without using builtin fuctions
Input- "java"
output-" j a v a"
That is inserting a space in between two characters in a char array
In a char array without using any built in functions like append. if possible provide the code also
    @anoop-SlERLg • Mar 14, 2019
    I will give you logic
    For  int i = 0  to inputString.Length -1
        If i == 0
            print inputString.charAt(i)
        Else
            Print <space>
            Print inputString.charAt(i)
        End If
    End For loop
  • Harsha Swamy
    @harsha-7EB6cz • Mar 14, 2019
    no bro doesn't work
    Give your code please !
    I don't see any issue with the logic. I created a code snippet and it works fine.
  • Harsha Swamy
    My bad it actually worked thanks Anoop....
