  • How To Add RTC In Raspberry Pi ?
    Updated: Oct 26, 2024
    Views: 1.4K
    Computers have coin sized RTC module which keeps the correct time even when the computer is OFF. In raspberry Pi it is not added. It checks the time from internet & updates the time.
    I would like to know, how can I add externel RTC for raspberry pi, if possible. so even when my RPi is turned off & restarted, the time is set without need of internet connection.
    Help ?
  • Jeffrey Arulraj
    MemberAug 8, 2013
    Computers use a seperate battery powering the system clock and this keeps the system time upto date even when the system is turned off
    So if you can power the clock in R Pi using an external battery You will have continuous time even if you turn off your R PI
    I know that.
    I wanna know : HOW ?
    -Bump-
  • Jeffrey Arulraj
    MemberAug 9, 2013
    I am not a expert but this link looks really promising
    Be careful not to ruin RPI while following the steps in the link
    <a href="https://learn.adafruit.com/adding-a-real-time-clock-to-raspberry-pi/wiring-the-rtc" target="_blank" rel="nofollow noopener noreferrer">Wiring the RTC | Adding a Real Time Clock to Raspberry Pi | Adafruit Learning System</a>
    Conqueror
    This is perfect solution. #-Link-Snipped-# you need to interface external RTC which has battery backup too.
    Yeah! Working on it 😁
    Abhishek Rawal
    Again ! Make sure to check supply voltage for the RTC chip you are using.
