How the static constructor is used in object creation?
patil.ashu01
@patilashu01-wqV4iY โ€ข Oct 21, 2024
Hey friends, I am stuck here understanding static constructors. Have gone through many posts and online articles. But I am unclear yet. It says static constructor is called automatically before the first instance is created. But instance is created using default constructor, then how the static constructor is used in object creation? I know I am making a weird mistake but confused. Please help.
    @anoop-kumar-GDGRCn Jan 9, 2013
    would you please specify which language you are talking about?
    As per Java, if you declare a constructor as static it will not longer be "a" constructor.
  • patil.ashu01
    @patilashu01-wqV4iY Jan 9, 2013
    Working in C#
    ianoopwould you please specify which language you are talking about?
  • rahul69
    @rahul69-97fAOs Jan 10, 2013
    patil.ashu01Hey friends, I am stuck here understanding static constructors. Have gone through many posts and online articles. But I am unclear yet. It says static constructor is called automatically before the first instance is created. But instance is created using default constructor, then how the static constructor is used in object creation? I know I am making a weird mistake but confused. Please help.
    ๐Ÿ˜€ I am going to tell the basic concept of static constructor which will clear its usage :
    Static constructor is used to initialize the static variables.
    Now if we initialize the static variables using the normal (ie non static) constructor, its value will be re-setted every time a new object is created.
    And regarding ur question, if we have not created static constructor, then only default constructor will be used. I hope ur doubt is cleared ๐Ÿ‘.
  • patil.ashu01
    @patilashu01-wqV4iY Jan 10, 2013
    rahul69๐Ÿ˜€ I am going to tell the basic concept of static constructor which will clear its usage :
    Thank You...
  • rahul69
    patil.ashu01Thank You...
    you're welcome...
