How does the sun cause heat on our bodies?
The Observer
@the-observer-Vms2ZU โ€ข Oct 26, 2024
Hello,
I felt this question relates a lot of radiative heat transfer and hence i'm posting it here. Actually came up during the moonlit night yesterday. It was disturbing my pillow ๐Ÿ˜›
When the sun shines... as far as i can think there may be 2 ways by which it produces heat.
1. The sun rays are a source of infrared radiation. Is that causing the heating up of our skin ?
2.The photons from the sun light hit out skin and friction between our body atoms and those from photons cause heat to be generated.
which of this applies?
Also contrary to this..
If light from the sun could make warmth. Why is light from the moon causing a cooler atmosphere?
One possible explanation is that when we see a moon lit night.. it is usually cloudless and cloud act as insulator trapping the heat from the earth's surface. So, is this the real reason why cloudless and moonlit nights tend to be cooler than the cloudy nights where the moon isn't so much visible and the clouds tend to gather all the heat and insulate the atmosphere.?
Is the reflected light from moon also a source of infrared radiation ?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Oct 15, 2013
    The ObserverAlso contrary to this..
    Moon's light There is nothing called moon's light It is just Sun light reflected
    When Sun energy hits moon The moon gets energized and so it glows and that is why we are able to see it in the night sky
    Any Media excited by IR radiation is a source of IR raditaion i.e All Hot bodies can produce IR radiation
  • The Observer
    @the-observer-Vms2ZU • Oct 15, 2013
    so you mean the light reflected by the moon is of such less intensity that it doesn't have enough IR radiation with it for producing some warmth us on earth ๐Ÿ˜” ?
  • Jeffrey Arulraj
    The Observerso you mean the light reflected by the moon is of such less intensity that it doesn't have enough IR radiation with it for producing some warmth us on earth ๐Ÿ˜” ?
    Cent percent
    Just imagine this allegory put your hand into fire it can burn your skin really well In the case of a vessel just kept on the flame you can touch the vessel without much change
    That is the case here too
    Moon reflects sufficient IR needed to sustain the life during the better half of the day
    @anoop-kumar-GDGRCn • Oct 15, 2013
    Apart from light source there are two more factor come with sun light/
    Ultra-violet rays + infrared.
    Ultra-violet makes sun rays hotter and is main reason of sunburn, basically because it is causes ionization.
    Reason is having more energy electron at higher frequency 8*1014 to 3*1016 Hz. while visible light frequency ranges from 4*1014 Hz to 8*1014 Hz.
    See here: #-Link-Snipped-#
  • The Observer
    ianoopApart from light source there are two more factor come with sun light/
    but light is considered to be of photons right?
    Yes, light consist photon but sun rays consist radiation too which is not visible via necked eyes.
    Ultra voilet + infrared. Thank to Ozon layer which absorbs most of the uv rays.
    Try Halogen bulb ๐Ÿ˜€
  • The Observer
    ianoopYes, light consist photon but sun rays consist radiation too which is not visible via necked eyes.
    oh. yes. now that fits the theory well . thanks.
    @ramani-VR4O43 • Oct 15, 2013
    Sunlight intensity on earth surface - 100,000 lux
    Moonlight intensity on earth surface - 0.2 lux
    This should explain all.
    True, but if you observe sunlight feels like an arrow when you are near to equator. Because it less reflected through air.
    Ok, how many of us, here, believe that sun intensity also depends on earth and sun distance?
  • Jeffrey Arulraj
    ianoopOk, how many of us, here, believe that sun intensity also depends on earth and sun distance?
    I believe and I am sure all will believe
    That is one of the reasons why winter day are more pleasant in Chennai,India When compared to Day time during the month of May
    Such a small variation in distance has resulted in nearly 10 degree drop in temperature
    PS: Temperature is a measure of heat falling on the surface right?
    There is no great difference in distance between winter and summer. The angle of incidence changes. The intensity at any angle = intensity at normal incidence x cos(angle of incidence)
    Jeffrey SamuelI believe and I am sure all will believe
    So, sun is farthest when it's winter?
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Oct 15, 2013
    My understanding here is , we sweat and we feel our bodies heated when exposed to sun because 70% of the body is made up of water.
    And because of the suns heat, we feel our bodies heated.
    I think, this is the reason we should wear pressurized suits if we are above the amstrong's limit as water boils not at 100C but at much less temperature.
