    @harshad-ukH5ww • Jul 28, 2012
    MDK ๐Ÿ‘Ž Ho does a SENSOR system works?๐Ÿ˜ณ โ€‹
    Can you please provide more details regarding your question.
  • [Prototype]
    @prototype-G9Gn5k • Jul 28, 2012
    As a generic answer, various sensors are manufactured with materials that have some kind of relationship with voltage, resistance or other parameters.
    For eg. an Infrared sensor could be made up of such a material whose resistance decreases when infrared light falls on it thus giving you an output in voltage which is proportional to the incident light.
    @ramani-VR4O43 • Jul 28, 2012
    Sensors in general show a change in one characteristic as a function of the parameter that is measured. Though in instrumentation we generally consider an electrical output (Resistance, voltage or current), a sensor may have a mechanical, chemical or physical parameter change.
    An RTD shows a variation in resistance with temperature. Litmus paper changes colour with pH. A bimetal strip bends with temperature. A manometer changes level with pressure. And so on.
  • munesh kumar
    @munesh-kumar-X9x4z2 • Jul 28, 2012
    any type of sensor changes the physical quantities to proportional function of voltage,resistance,mechanical deformation,.
