How do we get order of an Algorithm?
mech_guy
@mech-guy-TMwuj2 โ€ข Oct 25, 2024
Hi All,
The efficiency of algorithm is defined in terms "O" notation. I am clear to some extent but i have some doubts too.
If for a particular algorithm, i employ a "for" loop that loops once over all "n" numbers order is O(n), if twice we loop it becomes O(2n), if a "for" loops inside another "for" loop it becomes O(n^2).
My doubt is how do they get O(n log n) or O(n^2 log n) ?? That is, am not clear how do they chip in this "log" ??
For example "Merge sort" algorithm is O(n log n). How do we get these numbers (log)?
Thanks in advance for helping ๐Ÿ˜€
Regards
  • skipper
    @skipper-wJtaxo • Jul 28, 2009
    Order notation is an approximation of the amount of time it will take, for an algorithm to process some input. Approximate because it doesn't guarantee the algorithm will halt, for all inputs.
    You need the recurrence for the algorithm, Tn: Tm, Tm+1, ..., Tn-1, Tn; m = 0,1,2,...
    The reason a sort is more efficient than simply iterating over a set each time, is because even a binary sort is log2, better than 2n or n^2 = worst case.
  • mech_guy
    @mech-guy-TMwuj2 • Jul 29, 2009
    Hi skipper,
    Thanks for replying but i guess you didn't get my question.
    I want to know how an order of algorithm is expressed in terms of "log". Where from this "log" comes?
    Hope its clear now ๐Ÿ˜€
    Thanks
  • tashirosgt
    @tashirosgt-7BsIre • Jul 29, 2009
    Example: I've picked a number x between 1 and 64. Guess which number it is.
    Use the algorithm that asks a series of questions like:
    Is x >32?
    No
    Is x > 16?
    Yes
    Is x > 24?
    No
    Is x > 20?
    etc.
    After about 6 questions you know the answer for x.
    2[sup]6[/sup] = 64.
    6 = log_of_64_to_base_2
    For N things, you need about log_of_N_to_base_2 questions.
  • sarveshgupta
    @sarveshgupta-txtmu5 • Jul 29, 2009
    In Merge sort the computational time is divided into divide time, combine time and comparison time
    Its recursion is T(n) = 2T(n/2) + theta(n) + theta(1)
    2T(n/2) = division time
    theta(n) = combine time
    theta(1) = comparison time
    note when we use Master Method to solve this recursion we get O(n log n)
    In any sorting algorithm or any other algorithm where the increase in number of terms(in case of tree) or reduction in number of terms take place( as in case of sorting)
    when we generalise the case such as
    1 time : n comparisons
    2 time : n/2 comparisons
    .so on till only 1 comparison is left
    this means n/(2^i) = 1
    n = 2^i
    taking log on both sides
    i = log n base 2
    like this log factor comes in
  • mech_guy
    Aha!! Cool mates ๐Ÿ˜€
    Got it.
    Thanks a lot sarvesh and tashirosgt ๐Ÿ˜€
