How Do Under-powered Gadgets & Over-Powered Gadgets Affect The Gadget & System Connected To It ?
Abhishek Rawal
@abhishek-fg9tRh โ€ข Oct 25, 2024
There's a reason why Power consumption is mentioned in each & every electronics gadget.
The gadget works perfectly in the mentioned Power consumption unit, but not as desired if less than what's mentioned in specification.
I would like to know, what happens when gadget is under-powered ?
I think the gadget won't work at all, but I am not sure though. Can it damage any other component connected to it, if the gadget is under-powered ?
I would also like to know what happens if the gadget is over-powered ?
Consider i have GFX card which requires 500 W to run, but if I use 750 W then what can happen ?
What will be effect to the hardware & all other components connected to it ?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jul 27, 2013
    Over Current never practically occurs So if your over power is only cos of fluctuation in currents then it is absent in system
    Why?
    A load picks up only a fixed amount of current based on the applied voltage Higher currents never flow into them
    High pwer due to Voltage surges are dangerous to the equipment If the equipment is not capable to withstand this voltage surge it will be cooked for sure
    Voltage surge affects components without SMPS more So in a sense SMPS protects your hardware by self destructing itself
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jul 28, 2013
    Hey AR are you cleared man
    I some times feel that my language is not understandable So pls tell whether I cleared the doubt
    @abhishek-fg9tRh Jul 29, 2013
    I have heard that Under powered GFX card can damage the components.
    There are times when SMPS can get shorted which alongwith it take few other components to the death.
    So, I wonder if gadget is under-powered, how come the gadget is damaged ? ๐Ÿ˜จ
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jul 29, 2013
    The power fluctuations are due to Voltage fluctuations
    When Voltage fluctuations are within the 90 % to 110 % of the actual voltage requirement of the gadget the device turns on and off rapidly destroying the device completely due to severe or hyper transient effect
    Cumulative thermal breakdown occurs in the gadget that is fatal
